The clock is a quartz 14 inch model . on back this info -ref QXA221ST and HME07 battery rplaced 8 days ago now 2hrs 25 mins behind time what can I do?
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
SOURCE: My Lacrosse radio controlled clock (IECLR6) has
Mine does the same thing. I contacted the manufacturer and they told me there's nothing I can do to fix it. They suggested I return it if it's under warranty (which it isn't). With no warranty they said there is no way to repair it.
SOURCE: My WWVB radio controlled quartz
these really aren't atomic clocks and are set at the factory. It receives, it's LF signal out of Colorado and should correct itself. If not contact the manufacturer.
SOURCE: I have a La Crosse wall clock, model WT-3102. It
Sounds like it is not picking up the radio signal.
--- Please dont forget to vote this answer was helpful. Many thanks ------
Try placing it in a window overnight where the radio signals do not get obstructed.
SOURCE: Atomic Clock by SkyScan model # 28600. Clock
It does that until it receives a signal. Leave it overnight and it will probably get one. Instructions for this clock are at skyscaninfo.com
