Question about Canon CanoScan N670U Flatbed Scanner
Canon CanoScan N670U Flatbed Scanner Problem:
I CANNOT INSTALL IT IN WONDOWS VISTA PLSE HELP
Posted by ELFRID on
  • 6 more comments
  • korkycat Nov 26, 2007
    I have Vista too and the scanner won't work. It is recognised and Toolbox sees the scanner, the program starts to scan then hangs. In Control Panel it is shown as a scanner and successfully performs the diagnostic test. In windows fax and scan however it is not seen! I have scoured for similar problems and this is the first I have seen like mine. Can anyone help, it's driving me mad. I have a HO1010 laserjet that isn't supported in Vista and now this won't work. Well done Microsoft again.
  • CannotScan Apr 15, 2008
    I have the same scanner and installed the software that came with scanner in Vista. I selected English as the installation language and the scanner menu opens in Spanish. I have uninstalled and reinstalled 3 times with the same effect. I downloaded a patch from the Windows website with no success. My Canon i860 printer has issues as well. The printer is supposed to be plug and play in Vista. It will print but now with no preview screen as was supported in XP. So my scanner is now a "CannotScan"
    Yay Vista!
  • Seymourh Jun 09, 2008
    My Canon N670U has been fine for years, but does not work in Vista.
  • Dundonald Jun 19, 2008
    Same problem as CanotScan. Does not load on Vista
  • Bettz Aug 30, 2008
    This scanner will not work with Vista. I have just been through that and finally bought a new scanner. There is, at this time, no solution according to Canon.
  • bigshotphoto Oct 27, 2008
    Same here. Looks like vista needs to buy me a new scanner.
  • Anonymous Oct 31, 2008
    Ditto I too have the same problem I really like this scanner and I don't see why I should have to buy another one. Boo Hiss Vista!
  • patentes99 Apr 09, 2009
    I get the same error message now, and didn't use to.  But - I have Windows XP and recently updated all the patches etc for XP....don't know if its related, but the first time I use the scanner after updating Windows, I get that same error message.
Can't find my pictures from microsoft xp
did you upgrade from vista to windows 7 or did you install a new copy of windows 7? If you didnt upgrade then your old files will be saved in a folder called windows.old
Jan 24, 2013 | Microsoft XP Computers & Internet
How do you install drivers for the cm1015 on Wondows 7?
Donwload the complete solution for Vista from HP web site. Expand the file to a known directory. In that directory right click on the CM1017eGSG file, make it compatible with windows vista, right click it again and run it as administrator.
Voila!!!!
The program should be installing the drivers now!!
It worked for me
Feb 11, 2010 | HP LaserJet CM1015 All-In-One Printer
I Have Compaq Presario F700 Note Book I have downgraded it to wondows XP. I am unable to find and install its ethernet & sound card drivers.
This could happen because the drivers for sound and other are not their with Win XP.You require Win Vista for the sound and ethernet drivers.
Regards
Jun 26, 2009 | Computers & Internet
Blue screen ACPI.sys on install (brand new system, first install)
my client office one system working windows , when booting time displaying blue screen error" acpi.sys " . and then continusly system restart., but, i was maked the first and second repair, still now i didn't got solution for this problem. please help me. and also i want need ur help for blue screeen error.
May 15, 2009 | ASUS Computers & Internet
I need a Driver for lexmark x75 for wondows vista
I would like to inform you that X73 printer is not compatible with Windows Vista OS and there are no driver available. However, if you are a US citizen then you may contact Lexmark chat or email support and they will give you 20% discount if you purchase a new Lexmark printer.
Apr 09, 2009 | Lexmark X75 All-In-One InkJet Printer
Can't share internet over lan
You must share your internet to other computer using your lan connection in able other PC can open internet wondows.To do this
go to my network click set up home and small office network then follow up wisard set up before you close set up insert your cd windows installer e.g. xp or vista click additional task,click home and small office network again from cd follow wizard then click finish,then insert your cd wondows installer to other computer and repeat procedure on set up home and small network restart your PC everytime you install internet sharing,be sure one PC will assigned as server
Mar 06, 2009 | Computers & Internet
Help with error codes
seems firewall is blocking the updates. or you have a pirated vista that wont update.
http://windowshelp.microsoft.com/Windows/en-us/help/261ae42d-8c84-496e-88cb-a46dff5504611033.mspx
Oct 05, 2008 | Computers & Internet
Help me..whats going on with windows xp home edition
When installing a new operating system, all file saved will be deleted. Since you've lost all data, you might as well format the entire drive, and then reinstall the vista inspirat thing. Then, download an Avast! anti virus form avast.com. Download the home version, which is free and scan the computer for any viruses. Delete every last one of the suckers.
Jul 03, 2008 | Microsoft Windows XP Home Edition
Help
backup all your files onto disk, format hardrive, and insert your windows xp disk and turn your pc back on...you will have wondows xp, vista will be removed.
May 28, 2008 | Computers & Internet
Canon CanoScan N670U Flatbed Scanner Logo
733 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
