Question about Gateway FPD1975W 19" LCD Monitor
Get driver for monitor FPD1975W
Need windows 7 driver for Gateway FPD1975W 19" LCD Monitor
5 Related Answers
Anonymous
SOURCE: power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Posted on May 18, 2008
Anonymous
  • 585 Answers
SOURCE: my gateway monitor FPD1975W 19inch LCD won't turn
I have repaired similar FPD models. I have one of them on this very desk.
The GatewayFPDmodels develop problems after a couple or more years of use. Therepairsare fairly easy for the savvy technician. The power inverterboard inthe back of the monitor contains some capacitors, they may be470 and220 mfd or 680 mfd depending on when they were made, @ 10 16 or25volts, with a 105 deg. C temp rating. They go bad due to heatissuesand the currents they have to filter. Replacement of thecapacitorsusually restores operation. Use capacitorss of the sameratings as original for replacement.
Be advised, turning the monitor off when you are not using it will extend the life between these repairs.
Hope you find this helpful.
Posted on Apr 24, 2009
Jose Pino
  • 563 Answers
SOURCE: Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Posted on Oct 09, 2009
Anonymous
SOURCE: my gateway FPD1975W 19 INCH LCD MONITOR DOEN'T
(thank you budmrtn) my monitor shut off..i went online looking for solutions gate way fpd1975w..i looked hard for about 2 hours..i found a common problem was with the power supply..(budmrtn) hit it on the head..i am not an electronic expert at all..i have a soldering gun..thats is..no testers..so i took the monitor apart and found the power supply was a seperate board..i took it out and looked at it and said hmm. do i throw the 180.00 monitor out or do i take a chance..i took the chance..i went to radio shack and bought 10 capacitors like (budmrtn) said i replaced them..if it did not work i was out 10 buck and i was going to throw it away..but well and behold..i replaced the capacitors..just the big ones not the round blue ones..and wala..new monitor..it worked..crazy i no..but it worked..and i have a 19 inch lcd that works and i was going to throw it away..if you need to know what i replaced email me and ill let you know..
Posted on Feb 01, 2010
devverma143
Devendra Verma
  • 163 Answers
SOURCE: FPD1975W (Black) 19 inch LCD Monitor: power button flashes but not coming on...
Open the cabinet and remove CMOS battery and harddisk connection from motherboard.
And reboot the system. It will give the msg no boot device found. Now place again the cmos and harddisk and reboot
Posted on May 06, 2010
1helpful
Where is the microphone
That model does not have a built in microphone, you will need to get an external mic and connect it to your computer.
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
1helpful
I need a driver for a FPD 1975W LCD Monitor
Please mention the serial number of your monitor or visit below page to download the driver for it.
http://support.gateway.com/support/drivers/dlcenter.asp?Tab=My
Let us know further.
Thanks for joining us.
Have a nice day.
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Dont have a driver for itis one needed for mon
You do not need the monitor driver to use monitor, but you do need correct driver for your video card, but if still want the driver, here they are: http://support.gateway.com/s/MONITOR/7005574R/7005574Rsl.shtml
Just make sure to set the video resolution of your monitor to be at native resolution 1440 x 900 (native)
http://support.gateway.com/s/MONITOR/6895R/6895Rsp2.shtml
FPD1975W 19" gateway monitor
The stand is fix,but you can move up/dn little bit..
Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
MONITORS
Inverter Power board 19 Gateway Monitor FPD1975w
2answers
Power supply for Gateway FPD1975W 19 inch LCD
Gateway FPD1975W 19" LCD Monitor Logo
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Jessie Goss
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
