I need more input about this fender amp serial LO-324165
Http://intl.fender.com/en-CA/support/ Check this link.
SOURCE: fender M-80 electric Guitar Amp.
You might have a ground problem. Does it do it in different outlets or when you take it to someone else's house? One easy solution to ground problems can be running a three prong to two prong adapter on the power cable. Give that a try and see if it helps.
SOURCE: electric guitar pick up doesnt work?
se3veral things have to be ruled out, start with the cord that your using to your amp, is it good? next is the volume on both the guitar and amp also good, the last thing that should be wrong is the pickup itself unless a wire is broken off of it, you can usally check this from somewhere on the back of the guitar, if all the wires are good, check the two volume controls and on the back of the amp check the wires going to the speaker.
SOURCE: Fender Hot Rod Deluxe making popping noise
Ah yes, the Fender Hot Rod Deluxe. I have seen more of these in my shop than any other amplifier!! I have even sent recomendations for design changes to Fender about this amplifier.
Sadly, your amp tech may be correct: while the amp is within working specs, you can still have an issue with a bad socket. The cheapest thing to try is to replace the preamp tube(s) you think may be causing the problem. If the problem persists, it may need to be serviced on this issue (by a different 'certified Fender tech'). In defense of the last tech you had work on this amp, these amplifiers have a brittle design and do not gig or travel well (there are a minority of these amps made that do perform). Fender tried to do too much for the price on this model: best advice is to fix it, sell it and get your tone with a more stable model made by Fender (like the new vintage re-issues). Fender, like Marshall, has for years been having problems when they get too far from thier 'working reciepe' of what made them great companies.
You likely have a socket that needs re-tensioned, or a preamp tube not behaving. If it is not these, then a tech had to dive in the house of cards that is this circuit. Sorry for the bad news on this, but it is the truth. I only take on Hot Rods that 'appear' to be fixable. I am a development engineer, build amps from scratch and fix them for the local music shops, and my success rate is a dismal 60%-ish percent on these...
Thanks,-mike
SOURCE: I Have the fender 212 soild state amp.When I plug
You likely have a bad input jack. A VERY common thing with these. They don't like to work on the jack because one has to remove too much to replace it. Lazy shop! Sometimes the solder has just broken loose or the board pads damaged. Replace the jack anyway as they take a beating.
Find a shop willing to work on it properly and DON'T accept it back until it is fixed!
Another problem with amps can be the preamp output jack switch which fails to close leaving the amp dead... but it usually won't hum much when that happens.
HINT: Loop your instrument cord through the handle so when you trip and yank on the cord it won't break the input jack... saves a lot of jack repairs!
... do you, by any chance, have non humbucking pick ups on your guitar? Just curious...
