Air Purifiers Logo
Question about Air Purifiers
What is the 'Anion' button for on my eurolab air purifier
What is the 'Anion' button for on my Eurolab tabletop model air purifier? I can't find the instructiions, thanks.
1 Related Answer
Bob Duker
  • 96 Answers
SOURCE: The light on my S1719
Unfortunately, I can't find that information, as the company is currently in Chapter 11 and has sold off all rights to it's products as of June. From my experience though, when the light begins to flash, it is supposed to be replaced. At least I had to replace one that way while under warranty.
Posted on Jul 11, 2008
My Breathe Fresh, YD-700A, turns ON and ... HIGH, EFFICIENT, STERILIZER and Anion are lit up and will not turn OFF. What does this mean? and is it OK to run in low mode
There is always the possibility that the main control board has failed in that unit. The unit generates very high voltage and negative charges that leave the grid to trap small particles. With that in mind the board can accumulate a static charge and be ruined. Can you run it? I would not. There are cases where units similar to yours have caused fires.
3Q desktop Ionic Air Purifier Model 3Q-Ap-03 Switches on the side
I believe the beep when you initially plug it in is normal. I don't think this model requires replacement filters and if not, the beep is not related to a sign the filter needs replacement.
I also think that the buttons on the side reflect two different speeds at which the device may be set. I am unable to find a manual for this model. You may try to contact the manufacturer: https://the3q.com/pages/Contact-Us.html
WHEN I RUN THE DAYTON AIR PURIFIER, SHOULD ANION BUTTON BE ON OR OFF ?
It's up to you. Per Dayton, the anion feature is to remove odors.
My personal opinion is that is just a button for you to fiddle with.
The blue light on my Pro Shield ir purifier is staying on
do you hear arcing or snapping sounds when it's powered on? if so check to see where it's coming from, I posted a fix for this in some other posts. check the wires that run along the front of the cell plates, broken loose or sagging wires can cause this
Reset oreck XML professional
The reset button is power button,look at what it says under cell check button, hold(symbol) button t reset.
Can I get an owners manual for Hunter 30525 air purifier?
Yes, manuals are available from Hunter Air Technical Support. Call: 888-830-1326
Be sure to have the correct Model Number handy, when calling. As some models have been discontinued, but are still supported by Hunter Air.
Hope this helped you.
Lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
Professional Series Ionic Breeze Tabletop
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
1helpful
The light on my S1719 Sharper Image Tabletop Silent Air Purifier is flashing and the unit doesn't appear to be working
Top Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you an Air Purifier Expert? Answer questions, earn points and help others
