Question about Samsung SCX Office Equipment & Supplies
Entering power save mode
How to solve this problem
5 Related Answers
Anonymous
  • 293 Answers
SOURCE: my LCD monitor is going into power saving mode
Hi...there,
Your monitor enter to power saving mode to prevent further damaged. It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it...
Posted on Oct 13, 2008
Matampong
Trevor Sauna
  • 153 Answers
The monitor doesn't receive the signal from the PC. It is either the PC not booting up or the VGA coard is faulty. Change the VGA coard. or try reseting the VGA cord.
Posted on Nov 25, 2008
Anonymous
  • 285 Answers
SOURCE: My new Dell flat screen
You'll need to troubleshoot a little. SOmething may be broken, but you'll need to find out what. 1: Try the monitor on another computer, see wether it will work on that one. If it doesn't, the monitor's broken and you're probably going to need a new one. 2: If the monitor does work, put it back, but now use another cable to connect it to the PC. If that fixes it, your cable was broken. 3: If not, you could try to switch the graphics card in the PC with another one. Do not attempt that, however, unless you know what you're doing. If you don't, get someone you know to do it for you, or take it to a computer shop. If the PC will boot with another graphics card, the old one is broken. 4: If not, it may be your motherboard that's broken. Repeat step 3 with it. These steps should fix your problem. If not, please post back here. Regards, Yannick.
Posted on Jun 07, 2009
nyilasrobert
Robert Nyilas
  • 627 Answers
SOURCE: PC monitor warning error of PC entering power saving mode
it is CPU overheating problem, Go out and get some composite paste which is keeping the temp down
Posted on Jul 13, 2009
Anonymous
  • 389 Answers
SOURCE: Dell Monitor shuts down with "entering power save mode" command
There are times when you need to install software for a monitor to work with a PC. If you have the software disk that came with the monitor, you can try to install. You can also try changing the power cord to the monitor. Generally, power cords for PC's and monitors are the same. If you use your PC power cord and the monitor comes on saying that there is no connection with a computer, and it was not doing this before, you can get a new power cord for the monitor. If you can, try the monitor with another PC or laptop to rule out a bad monitor.
I hope these suggestions have given you a place to start and that they were helpful.
Brian
Posted on Jan 24, 2010
I open my computer today but suddenly the monitor says " entering power save mode" and its stuck there. ive tried to do simple ways to fix but still nothing. can someone help me? im using windows 7
Switch off and remove the power cable then put in the power cable again and switch on again...try to disable the power saving mode once it is on.
Apr 05, 2013 | Dell Computers & Internet
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
Computer Gateway SX2802-07 PC Desktop keeps entering power save mode
could be power mode is not set correctly. could be clock/battery is low and causing early saver mode? is your pc time/date correct?
is your ac adapter working properly or is it going bad?
Aug 24, 2012 | Gateway SX2802-07 PC Desktop
Gateway desktop enters power save mode while in use.
boot and adjust the power settings for all "when on A/C" to never. to take it out of power save press any key on the keyboard or press the power button (but dont hold it down)
Jul 08, 2012 | Gateway Computers & Internet
I have an HP Officejet 4500 g510 - how do you turn off the power save mode? Thanks,
Called Hp, they said it is a firmware problem and they would notify me when they solved it. All I do is unplug and then plug it back in. If that don't work, make sure you have a phone line plugged in you're printer and pretend to make a phone call, this will "wake up" the printer, it will say "phone off hook". Then on the keypad of the printer push the star and pound buttons at the same time, then enter 1, 2, and 4. Scroll thru until you see "system menu" then push the OK button and find "system mode timeout" push OK then enter 1800 and push OK. Push OK again to make sure. That is the dafault setting for this printer. After doing all that you're printer will go to power save mode after 30 minutes sitting idle but it should pop right back to normal by pushing the power button once or sending a print command from you're computer. At least that's what I did and now it seems to come out of power save mode when it's supposed to....gary
Nov 08, 2010 | HP Office Equipment & Supplies
Monitor displays "warning pc entering power saving mode
Hello
Sounds like to power settings were set too low. Restart the PC, before it gets to Windows press F8. This will send the PC into SAFE mode. You'll get a menu of which SAFE mode to select, just select SAFE mode with networking. Once in SAFE mode, go to START, Control Panel, Power Options. From there select new settings. Since this is a desktop, I would make the settings very long. Good luck
Mar 03, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
The pc entering in pwoer saving mode and
  1. Start or restart your computer.
  2. Press the F10 key when the F10=Setup message is displayed.
  3. Select the appropriate Language option.
  4. Select the Power menu.
  5. Select (if not already selected) the Energy Saver item.
  6. Press the Enter key.
  7. Select Advanced .
  8. Press F10 to save the change.
  9. Select Power > Timeouts > Hard Drive Timeout > Never .
  10. Press F10 to save the change.
  11. Select the Power > Energy Saver .
  12. Press the Enter key.
  13. Restore the desired Energy Saver Mode (Disable or Minimal).
  14. Press F10 to save the change.
  15. Select File > Save Changes and Exit .
Feb 03, 2010 | HP Compaq d530 PC Desktop
My LCD monitor is going into power saving mode
Hi...there,
Oct 13, 2008 | Computers & Internet
Sep 30, 2008 | LG L1915S 19" LCD Monitor
Pc entering power save mode
I am having the same problem . The system is starting up and th epc entering power save mode. I have a Hp pavilion f1503 model monitor. I hit the power off button on the power surge to shut the entire power off. I turn the power surge button back on. Sometimes it works. Or have to hit the power on button to reboot.
Dec 12, 2007 | HP Pavilion a810n (PP164AA) PC Desktop
19 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
