SOURCE: DRA-565RD: The receiver plays
In that case the problem is inside it: when the unit works it heats up and a piece dilates, touching the ground and shorting everything. Or the part dilates and loses contact causing a loss of power.
Open the unit and look very carefully for uninsulated parts, exposed or weakened solderings and damaged wires.
SOURCE: I have had a Denon
Your friend is correct. The transformer may be shorting. Just smell the transformer and see if you smell burnt enamel. That typical smell when an electrical gadget gets burnt. If yes then you must replace the transformer. Only you must get one of exactly the same specs. And fortunately, these days you can get a much smaller and a heavier duty transformer than what you have presently. You can do it at home.
SOURCE: denon dra-95vr receiver has no sound out. All
DRA-425 HAS NO SOUND, EVERYTHING ELSE WORKS. FOUND ONE FUSE THATS GOOD, ARE THERE ANY MORE. YHANK YOU
SOURCE: I have a denon dra 565rd used it yesterday it was fine.today i have no sound
https://www.cnet.com/forums/discussions/denon-receiver-problem-video-but-no-sound-328661/
https://www.hifiengine.com/manual_library/denon/dra-635r.shtml
