Question about Magic Chef MCWC30MCG Compact Wine Cooler
It does not let me control the temp. from the control panel. The Code read E.ET.
SOURCE: I have a magic chef
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
Posted on May 27, 2008
SOURCE: Power Consumption - Magic Chef Wine Cooler
The unit will draw between 6 and 12 amps on start up and running it should use less than 1.6 amps. The start up amps will increase with age. Funny how that works the same for people as it does for machines. I hope this will FixYa. Please dont forget to rate. Mike
Posted on Sep 24, 2008
SOURCE: E3 error code on my Magic Chef Wine Cooler - what
could be a broken fan, compressor gone, thermostat. neither one you can fix. you need a refrigeration mechanic or a new fridge
Posted on Nov 11, 2009
SOURCE: I am getting an E3 Error message on my temp
Do this...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician.
Here is how I resolved my e3 issue:
1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in"
Posted on Feb 08, 2010
SOURCE: The magic chef wine cooler was clicking now will not get cool .
its your ptc relay.its a very simple fix.to the left of the compressor is a plastic cover with 1 screw.take it off.youll see a small box on top with 1 wire going to it.wiggle it off.pulls straight out left of compressor.go to repairclinic.com..type in part #1206838.its about a $27.00 fix. mines been running fine since.hope this helps
Posted on Aug 07, 2010
Sep 25, 2013 | Haier BC112G Wine Cooler
Aug 10, 2013 | Haier BC112G Wine Cooler
Jan 22, 2013 | Magic Chef MCWC45A Wine Cooler
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
May 10, 2011 | Magic Chef MCWC44DZ Wine Cooler
Oct 05, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Oct 29, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Oct 03, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Sep 23, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
136 people viewed this question
