Question about SanDisk 4GB microSD High Capacity Memory Card
Netformx USB 2GB sectors - SanDisk 4GB microSD High Capacity Memory Card
My 2gb sandisk micro SD card reduce the size after formatting
Possible micro SD bad sectors. To check your micro SD bad sector or not, you use the HD Tune software. To restore the capacity micro SD, which is done is Low Level Format. You can use the software HDD Low Level Format Tool.
How to use HD Tune and HDD Low Level Format, you can see here
Transcend Repair Bad sectors
How to repair micro SD, you can see in here
MMC Repair Without Losing Data Video 2
Oct 12, 2011 | SanDisk 2GB microSD Memory Card
Hi friends, Actually I've a 2GB Micro SD it displays "Writing Protected" error while I trying to format it in windows environment with Third Formatting tool and It displays "msdc write...
Check the little white switch on the side of the memory card. That is the write protection switch. Turn it to the off position and try formatting again.
Apr 22, 2011 | SanDisk 2GB microSD Memory Card
How i fix msdc write sector error in memory card..........
sir i have a 2gb memory card but its not be deleted then i try to delete this , after loading show this message MSDC wright sector error, & then moved any file then show this message "access denied" please help me.
Dec 17, 2010 | Electronics - Others
My kingston usb says it has 7 gb free, but when i copy a movie file of 5 gb it says there isn't enough space.
is it a 2GB or a 7GB Kingston USB drive
control panel admistrive tools,computer management disk management right click on your drive select properties click tools you should see two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when resart
hope this helps
Dec 04, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Not formating
insert 2 GB USB go to control panel administrive tools computer management disk mangement you you can right click select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
hope this helps
Oct 12, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Using a Mac to transfer photos to a SD 2GB memory card. Halfway through, says it's full, even though it says there's space available!
The memory stick must have bad sectors in them. They are like a hard drive, they go by sectors, if one goes bad, it will shrink the size.
Nov 20, 2009 | SanDisk 2GB microSD Memory Card
I cannot format my kingston 2gb USB flashdrive.
The drive is probably infected with some kind of viruses which are capable of creating bad sectors. What I would suggest is to run a virus scan on the drive and see if it finds anything. Then run check disk or anyother diagnostic tool of your choice. Norton disk doctor(if you have it) is very good at this job. If it still doesn't work then I would assume that it is some kind of conflict in the USB controllers and will guide you through the troubleshooting that.
Regards,
Sai.
Dec 07, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
SanDisk 4GB microSD High Capacity Memory Card Logo
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
