Seiko Melodies in Motion Clock Logo
A
Anonymous Posted on May 04, 2014
My melodies in motion clock from sam s club year 2000 or 2001, ref: QXM109ZRH, is no longer operatable. battery compartments are rusted and some wiring has broken off. I loved it when it worked. Any way its fixable?
UsedClockPartsdotCom
Level 3:
  • Seiko Master 277 Answers
  • Posted on Jan 29, 2017
Seiko Master
Level 3:
Answers
277
Questions
0
Helped
147016
Points
4537
I would take it to a clock repair shop.
UsedClockParts.com
2answers
Need a manual for a Seiko melody in motion wall click. Model # QXM123BRH
Here is a manual for the Seiko Melody in Motion Wall Clock, Model # QXM123BRH:
Getting Started
  • Insert one "AA" size alkaline battery into the clock's battery compartment.
  • Set the clock to the correct time by pulling out the time-setting knob and turning it clockwise or counterclockwise to set the time.
  • Push the knob back in to the "Lock" position to finish setting the time.
Melody Selection
  • Press the "Demo" button on the clock's front panel to listen to all the available melodies.
  • To select a specific melody, press the "Melody" button repeatedly until the desired melody plays.
Volume Control
  • To adjust the volume of the melody, press the "Volume" button repeatedly until the desired volume level is reached.
Light Sensor
  • The clock is equipped with a light sensor that will automatically turn off the sound and motion sensors when the room is dark.
  • To disable the light sensor, push and hold the "Light Sensor" button for approximately 5 seconds until the "OFF" indicator appears on the display.
  • To enable the light sensor, push and hold the "Light Sensor" button again for approximately 5 seconds until the "ON" indicator appears on the display.
Motion Sensor
  • The clock is equipped with a motion sensor that will detect movement in front of the clock and activate the sound and motion sensors.
  • To disable the motion sensor, push and hold the "Motion Sensor" button for approximately 5 seconds until the "OFF" indicator appears on the display.
  • To enable the motion sensor, push and hold the "Motion Sensor" button again for approximately 5 seconds until the "ON" indicator appears on the display.
Nighttime Silencer
  • The clock is equipped with a nighttime silencer that will automatically turn off the sound and motion sensors during a designated period of time.
  • To set the nighttime silencer, push and hold the "Nighttime Silencer" button for approximately 5 seconds until the "SET" indicator appears on the display.
  • Press the "Melody" button to select the start time for the nighttime silencer.
  • Press the "Volume" button to select the end time for the nighttime silencer.
  • Push the "Nighttime Silencer" button again to save the settings and exit the nighttime silencer mode.
Troubleshooting
  • If the clock does not operate properly, try replacing the battery with a new one.
  • If the clock still does not operate properly, contact Seiko Customer Service for assistance.
Note: This manual is for general information purposes only and may not cover all features and functions of the Seiko Melody in Motion Wall Clock, Model # QXM123BRH. Please refer to the manufacturer's instructions for complete information on how to operate and maintain your clock.
Mar 03, 2023 • Home
1helpful
Have 3 different melodies in motion whistle with clock 1 bag pipe player and a clown playing a horn all with corroded battery compartment where can I get those fixed?
this is just personal info maybe not the best info ...but if it were me i would use a little sand paper and gently clean the battery terminal (where the connection between battery take place) (careful of the wires) to see if that solves the problem
Dec 08, 2022 • Motorcycles
My melody in motion clock is making a whistling sound
It a guess, but the batteries need replacing. Try that first.
There is a 'Sailor Clock', that is supposed to whistle!
https://www.google.com/search?q=melody+in+motion+clock+is+making+a+whistling+sound
Where can i get new batteries for seiko marinette melody clock
Possibly 4 D Batteries according to this Amazon sale item.
https://www.amazon.com/Seiko-QXM478BRH-Melody-Motion-Clock/dp/B0064C2CRM
Another possibility is if dead batteries are still in the clock to remove them. and identify them.
Seiko QXM478BRH Melody in Motion Clock
Aug 26, 2018 • Home
2helpful
2answers
My mother-in-law has a Melodies in Motion Clockpost Willie clock that she no longer has the instructions for. She can't figure out how to make him whistle. Can you point me to an ownder's manual?
Hello, Sherry -
I have not been able to find instructions online for the Seiko Melodies in Motion Clockpost Willie (a clown figure standing along side a clock on a post.)
The Melodies in Motion clocks are manufactured by Seiko Clocks. This is the link to the Seiko Clocks home page:
https://www.seikoclocks.com/
Near the bottom left of the home page, you will see the link to Customer Care. Click or tap on that link.
On the Customer Care page you will see the toll free phone number and the email address to use to ask if the instructions for the clock are available and how your mother can obtain them.
Best wishes.
Feb 23, 2018 • Home
1helpful
How do I change melodies?
The melodies should change each hour on it's own. You can change the melodies manually by pressing the demo button repeatedly. If the songs don't change each hour, you might try new batteries. I'd recommend Japanese batteries like Fuji, or Toshiba. I use Varta which is a German brand battery that's equivalent to either Duracell, or Energizer, and have no problems. If you've had the clock for a number of years, or have had it hanging in direct sunlight, or near a heat source it could be in need of professional assistance, and or repair. (if possible)
Why will my clockl no longer play song or move
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling
UsedClockParts.com
Seiko clock battery corrosion.
Use vinegar to clean out the battery compartment. It will neutralize the battery acid. Then take what is left of the springs and pull them out so they make contact with the new batteries. Sounds like you got a hold of some bad batteries.
3helpful
2answers
My seiko musical wall clock doesn't play music anymore
To test your Seiko Melodies in Motion Clock:
1) Check the volume knob in the back of the Seiko clock to make sure the volume has not been adjusted all the way down.
2) Make sure the on / off switch is set to on.
3) If it is extremely dark in the room, the clock will not play, it has a light sensor. Make sure the room is well lit.
4) There are separate batteries usually that operate the clock and the music. Change the batteries paying special attention to any acid / corrosion caused by old batteries. Clean out any acid and it should play. Also, be careful not to touch the positive or negative contacts on the new batteries, as this could inhibit proper connection.
If you have done each step above and it is still not operating, your clock is defective. Contact Seiko Service Center directly at: 800-722-4452 extension 3.
If you have had the clock less than a year, and it was purchased from an authorized dealer, it is under warranty, and any repairs will be free. Otherwise, there may be a charge for the repair.
Top Seiko Home Experts
ZJ Limited
ZJ Limited
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Seiko Home Expert? Answer questions, earn points and help others
