Question about Canon FS40 Camcorder
How to transfer videos from camcorder - Canon FS40 Camcorder
SONY CAMCORDER DCR-TRV19 DOESN'T WORK ON WINDOWS
The Windows 7 Operating System is not compatible with the USB Streaming feature of the Camcorder.
You can transfer the videos to the Windows 7 Computer using an i.LINK (Firewire) Cable.
You can use the Windows Movie Maker Software to transfer the videos from the Camcorder.
Please follow the steps mentioned in the below link to transfer the videos from the Camcorder to the Computer
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Mar 10, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
Unable to transfer video information onto PC ACER ASPIRE using windows Vista for editing by windows movie maker. Interface on PC is via USB. If software driver for firewire or 1394 interface is available...
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!
Sep 28, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Cant transfer videos to pc
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Option 3:
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Sep 17, 2009 | Sony DCR-TRV285E Digital-8 Digital...
Video transfer
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
or
There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
Jun 07, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Transferred videos from Sony Handycam Camcorder dont have sound
iorgsoft mod converter will solve the problem http://www.iorgsoft.com/Mod-Converter/
Feb 18, 2009 | Sony Handycam Camcorder
Hello, I need to know how can I transfer the video material to my pc, because I've find difficult in doing it, the camcorder is nott recognized in the video mode, and when I try to open it in my pc, it...
There are few things need to do in camcorder and PC for correct communication for video data transfer..
Install Picture Package software CD in PC supplied with camcorder.
Enable USB Streaming by going in to camcorder Menu.
Camcorder and PC must be connected through iLink / DV / IEEE1394 cable for video files transfer.
Let me know if you feel any difficulty.
Jan 13, 2009 | Sony Handycam DCR-TRV480 Digital Camcorder
My SC-DC163 camcorder does nothing when I try to upload videos to my PC.
the way you can transfer your videos on your computer is by using USB cable and install the driver to your computer. You can upload your videos by saving it on ULEAD products. As far as i know you cant transfer videos from disc to your memory card unless it was been converted but you cant view or watch it on your camcorder itself only computer can play this because your camcorder is not able to play such converted files.
thank you for using fixya
CHARCOIS
Nov 06, 2008 | Samsung SCDC163 Camcorder
Transferring from camcorder to VCR
Hello!
Here is a link to the manual.
Hope it will help you transfer the video.
https://manualsbrain.com/en/manuals/1046565/?page=56
Jan 04, 2018 | Panasonic SVAV100 D-Snap MPEG4 Digital...
Sony DCR TRV285E software
Please send the software for sony dcr-trv285e to transfer the video clips onto my computer
Apr 21, 2008 | Sony Handycam DCR-TRV140E Digital...
Transfer video from vhs-c to my pc
I have an Canon DC210, Is it possible to transfer the video from my camcorder to my pc, and if so what do I need. erwin thanks
Apr 15, 2008 | Canon DC210 DVD Camcorder
Canon FS40 Camcorder Logo
19 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
