Question about Canon ZR85 Mini DV Digital Camcorder
How to connect Zenith VM6200 camcorder to computer?
I have this vidio camera, Zenith VM6200 we don't have the manaul to find out how to get the tape out. I don't want to buy a 30.00 book for 1986 camera. Can you help anyone?
on the back there is a eject button, but you need to turn the camera on first, with the battery or power supply. Hope this helped
May 05, 2014 | Zenith Video Cameras
I can"t to download my new camcorder mpeg4 to my
Follow the steps below to troubleshoot if the computer does not recognize the USB connection from the camcorder.
  1. Turn off the camcorder.
  2. Ensure the USB cable is connected securely to the camcorder.
  3. Ensure the other end of the USB cable is connected securely to the USB port on the computer. NOTE: Connection through a USB hub is not supported.
  4. With the exception of the mouse, keyboard, and camcorder, remove any other USB connected devices from the computer.
  5. Turn on the camcorder.
  6. On the camcorder LCD screen, touch the computer or hard disk icon.
  7. If the issue is still not resolved, connect the USB cable to a different USB port on the computer.
  8. If the issue is still not resolved, try uninstalling and reinstalling the USB driver
  9. If the issue is still not resolved, test the USB port on the computer by connecting a different USB device.
Jan 01, 2011 | Video Cameras
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Dec 28, 2009 | Pure Digital Flip Mino Digital Camera
Driver
had Lost My Zenith Webcam Driver CD and now I can not find its driver.can you help me? My e-mail: [email protected] thanx
Sep 15, 2008 | Zenith VCM450 VHS-C Analog Camcorder
Connection
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Canon ZR85 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
