The speakers work but the subwoofer has no bass
Not much info to go on here, but my thought would be you have blown the woofers in the speakers, or the crossover in the cabinet, that separates the highs from the lows. . If you can touch the woofers with your hand, spread you hand wide over one, and try to move the cone. If it makes a scraping sound , the speaker is blown. If not,the crossover is probably damaged.
SOURCE: Surround Sound Speaker
It sounds like you need to define the speakers to the PC. Find the icon that controls your Sound Card and dabble with it.
SOURCE: I think the subwoofer power
If it makes any sound at all the speaker is probably not blown, the connections are probably on and the fuse is ok.
You don't say to what it is attached and if the setup for bass/lfe managament settings produce the same or a different result than program material does.
You also don't say how the sub is driven (speaker level or Line Level) and if it's a full-range or low-frequency-only input. All these things matter, as does your source electronics and its settings for bass management.
Try setting the low-pass higher and the high-pass lower.
The manuals would be a good place to start. Go to retrevo.com.
SOURCE: I have bose acoustimass 15.
your acoustimas requires you to connect all speakers outputs to it first then to the speakers.
