What is the max SD card size for the pentax optio S50?
SOURCE: 4gb Memory card error
In order to use 4gb memory your camera has to be approve for SDHC use.
If it isn't the most memory you can put into your camera is 2 gb
SOURCE: Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
SOURCE: Pentax Optio 60
Largest card for the Optio 60 is 2GB. The camera is not able to take 4GB and larger SDHC type cards. If I answered the question to your satisfaction, don't forget to rate it. Thanks
