Question about Magic Chef MCWC30MCG Compact Wine Cooler
The control temperature panel shows E.ET. you can't control the temp from the panel.
SOURCE: I have a magic chef
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
Posted on May 27, 2008
SOURCE: Magic Chef Wine Cooler Model MCWC44DZ Where can I
On the Magic Chef site you can order parts for the cooler. I took mine out and treid to find them on the web somewhere else and could not locate them anywhere except China and England. I know this isn't true but tried every search option I could think of. They are about $22 plus shipping (HIGH). You might try the following: http://www.fixya.com/support/t1814377-magic_chef_mcwc44dz_e4_error
Posted on May 17, 2010
SOURCE: The magic chef wine cooler was clicking now will not get cool .
its your ptc relay.its a very simple fix.to the left of the compressor is a plastic cover with 1 screw.take it off.youll see a small box on top with 1 wire going to it.wiggle it off.pulls straight out left of compressor.go to repairclinic.com..type in part #1206838.its about a $27.00 fix. mines been running fine since.hope this helps
Posted on Aug 07, 2010
SOURCE: Magic chef wine cooler (30 bottles) is not cooling any more
if its clicking every few minutes its the ptc relay.located to the left of the compressor behind shield with 1 screw.go to repairclinic.com...part# 1206838
SOURCE: I have a Magic Chef
There a couple of power supplies that run the fan, and you probably have a bad power supply, that needs replace or repair, try changing out the lectronlytics caps on the power supply modules .
Posted on Feb 04, 2011
Jan 13, 2018 | 2006 Volvo XC70
Feb 03, 2016 | Freezers
Sep 25, 2013 | Haier BC112G Wine Cooler
Aug 10, 2013 | Haier BC112G Wine Cooler
Feb 27, 2013 | Magic Chef MCWC30MCG Compact Wine Cooler
1,270 people viewed this question
