Coby Kyros Tablet Logo
l
lkjbihvcik Posted on May 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a place you can go to buy a teacup pig in ny?
Mike M
Level 3:
  • Coby Master 3,349 Answers
  • Posted on May 05, 2014
 Mike M
Coby Master
Level 3:
Answers
3349
Questions
0
Helped
686182
Points
16707
1helpful
Since the last system upgrade it sometimes connects to my WiFi and sometimes it doesn't.
Try resetting your router by unplugging the power cord for 10 sec and then pig it back in. Also check to make sure that your cable connections to the internet and router are secure. This may help with the problem.
1helpful
My tablets charging connection has slipped farther into tablet, how do I fix this?
The USB connector is a weak link in tablet construction. Usually it is just held in place by the solder although sometimes there is a bit of glue dabbed on it for strain relief. Most low cost tablets are not worth being repaired by a technician, so if the connector is still working, you could try to pull it out to the proper alignment and squirt a little crazy glue in to hold it in place. If the connector is not working, toss it in the recycler and buy a new one. And buy the extended warranty.
How do I delete videos on ny samsung 4 tab
1.home screen tap apps
2.tap gallery
3.navigate desired folder
4.tap menu
5.tap select item
6.select the items to delet
7.tap trash can
8.tap ok
Android tablet will turn on an make it to the word android on the screen, an not go no further. It will not turn off with out hittin the reset button. I need a bit of help please. I have tryed all the...
I will try to help you solve this problem. First you may have pressed the on and off button and the volume button at the same time. This is no pig problem. It will come back on after a while without doing any thing or you can try rebooting it back on to factory setting. Mine did the same thing and when I just waited later it popped back on.
Does anyone know how to root the Coby Kryos 8 inch MID-8127 tablet?
You do not have to be a guinea pig. But I imagine technology has not changed that much since you had the 7 inch tablet and I would give it a try, since there probably is no other way to solve this.
The screen in my Coby Kyros Mid7016 broke were can I ship this to be fixed.
You must contact Coby first. Here are the various ways to contact them:
2helpful
WHERES JUSTIN BIEBER
he went to poop and the pigs ate him
My keyboard broke and since I can it take it off, id like to know where I can buy a replacement I don't want a regular keyboard, I want the same one that came with the computer. help?
You can't buy a new keyboard ecause they stopped making it since 2005 but you can buy an old one. I think the best place to buy it is ebay, you can get one for quite cheap.
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
