Question about Delta Faucet Delta RP17453 Pull-Down Diverter Tub Spout
Water leaks between the pull down spout and the bathroom tile
nickygon
    Novelist:
  • 98 Answers
It sounds like your spout supply nipple has sprung a leak. There isn't much of any other way water can flow between your spout and tile wall. It's pretty important that you don't use the fixture until the problem is fixed. Because the water coming out that you see is also probably flowing into the wall and causing water damage and MOLD. You need to remove the spout and replace the nipple that is supplying the water to the spout. There could be a defect in your spout too, but likelihood of that is less than your nipple threads giving in to some electrolysis from the bronze/copper in the spout or somewhere in your water system. To prevent it from occurring again, use a brass nipple to replace the galvanized nipple in it now. Red brass, no yellow brass. Good luck with your problem and always know where and how to turn your water off to your house before attempting a plumbing repair.. Most spouts screw off. Counter clockwise, use a pair of channel locks by inserting the rubber coated handle into the opening on the spout then using the leverage of the channel locks to unscrew the spout off of the wall. It is not a repair that requires to have the water off to your home before attempting to repair. It only emits water when the tub valve is turned on. If it doesn't unscrew, twist it until the under side is up and you will see a slot where you can insert an allen wrench to loosen it and then slide off. Inspect the spout while it is in your hands to see if it is damaged of if the nipple sticking out is damaged. one of the two must be, because water flowing from behind the spout is definitely not normal and definitely something you need to fix right away, before your wall and floor behind your tub are damaged or start to grow mold.
Posted on Mar 26, 2015
3 Related Answers
jpintore
  • 129 Answers
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Posted on Oct 05, 2009
Anonymous
  • 111 Answers
SOURCE: The pull down diverter will
replace spout.if your lucky you can simply unscrew it.some are held with a allan screw underneath
Posted on Jan 27, 2011
Carl W
  • 343 Answers
SOURCE: Hi , i have a
You can take the part to your local Ace or True Value hardware store or Home depot or Lowe's and find something close that will work. Bring the whole part with you. Buy a few sizes that or close just in case, they are very inexpensive.
Thanks for using FixYa
Posted on Jun 22, 2011
I have a water leak in bathroom not from toilet. How can I check the pluming in that area?
Your idea may correct. But majority of cases it is floor/ground seepage....leaks through your tiles or waterproofing layers and so on..To chk...keep on pouring water to the ground of the bathroom, near wetting areas, and close the freshwater line leading to the bathroom taps
May 18, 2016 | 2006 Tahoe Transport
Slate bathroom tile
First clean floor down to plywood. Then buy mastic, notched trowel and tile spacers from hardware store. Lay out tile in the pattern you want by cutting them with a tile saw you rented. take out dry laid tile and mastic a small area and install til making sure you press the tile into mastic. Insert spacer and install next tile.
May 16, 2013 | Home
Where does the rubber membrane go when tiling a bathroom floor
tiles on wooden floors will always move and crack the grout/tiling cement
therefore the rubber membrane goes down first with out nails and then everything is laid on top
that way when the wooden floor moves , there is a water proof membrane to prevent the water from rotting the wood over time
Jun 14, 2017 | Home
Kohler rite temp with diverter. When the tub is turned on water leaks out the shower head. Changed the diverter didn't fix problem.
You could have a restriction in the tub spout or just too much pressure. Diverter only restricts flow to tub spout so any restrictions to the tub spout will cause water to go up to shower head.
May 13, 2011 | Kohler K-T396-4-BRZ Devonshire Single...
I a leak under my tub, think it's from the shower, it doesn't leak with a full tub of water or ewhen you empty the tub, but when you're in the shower a flow of water comes out under the shower piping side...
Check out the faucet plate mounted on tub side for a good seal. Water can leak down this plate causing it to look like the valve is leaking.
When you are in the shower it splash's water against the valve and water will run down behind it. Check the tub spout and if you have tile check the chaulked joint where tub and wall meet.
Jun 02, 2010 | Plumbing
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
Feb 23, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
When I run water through this tub spout (diverter in down position) I still have water leaking from the showerhead. I have seen water from a tub spout when the shower is on, but not the other way around....
After you turn water off in about 30 secs pull the diverter up and leave for a few minutes This should allow the water left in shower piipe to drain out the spigot
Feb 17, 2010 | Speakman S-1555 Versatile Bath...
I have a slow leak coming from the spout
ooops, didn't mean for that to be a request, sorry...It was a solution. Although, if you dont want to deal with Moen, you can get one at your local plumbing suplly store. I recommend taking the old one with you (make sure you shut the water off first!). Again, good luck
Sep 03, 2009 | Moen 4621 Chateau 1 Handle Bathroom Faucet...
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Delta Faucet Delta RP17453 Pull-Down Diverter Tub Spout Logo
550 people viewed this question
Top Delta Faucet Plumbing Experts
Muntejaya Ginting
Muntejaya Ginting
Bill Johnson
Marvin
Marvin
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
