Question about Kirby G6 Bagged Upright Vacuum
How do I replace a kirby g7 drive pedal? - Kirby G6 Bagged Upright Vacuum
Rocky
  • Kirby Expert
  • 324 Answers
Here is a step by step walk through with pictures on how to replace the neutral / drive pedal on any Kirby Generation vacuum (G3, G4, G5, G6, Ultimate G, Ultimate G Diamond Edition, Sentria and Sentria II)
Kirby Neutral Drive Pedal Replacement Guide
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Posted on Oct 15, 2014
1 Related Answer
b0sslady2001
Marci Marple
  • 357 Answers
SOURCE: kirby neutral/drive pedal
HELLO, JUST USE THIS GUIDE! :0)
http://reviews.ebay.com/REPLACING-OR-REPAIRING-KIRBY-VACUUM-NEUTRAL-DRIVE-PEDAL?ugid=10000000011180003
HOPE IT HELPS! :0)
Posted on May 17, 2012
How to repair drive pedal kirby
You will need to remove upper cover ,then remove the three screws
holding the trans in. Slide out the old drive pedal reuse the cam arm
and install new pedal. Slide trans back in and reinstall belt,reinstall rear screw first then the other two . replace cover and test N/D pedal.
Jul 30, 2014 | Kirby Vacuums
My g7 will not pick up anything
Without more information, my first guess is a worn or broken fan. You can take it to a shop and have it replaced, or buy one from a Kirby store and replace it yourself. There are also on-line stores where you can purchase impellers.
Here are instructions for replacing the fan:
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302
Here are video clips showing how to do it yourself.
http://www.youtube.com/watch?v=WJvw4NujOpU
http://www.youtube.com/watch?v=wS9nrQr_Kvc&feature=related
Feb 12, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Kirby g5 techdrive n/d pedal came off will not stay on
The pedal will need to be replaced. A shift mechanism pressed on the end of the shaft has come off and cannot be re-installed. The drive unit must be removed from the machine, and the pedal assembly and shift cam can then be replaced. This may not be a do-it-yourself repair, as a good deal of disassembly is required.
Feb 04, 2011 | Kirby G5 Bagged Upright Vacuum
G7 kirby not turning ON.. have checked both safety switches..ok... any ideas??
this happened to my G4, mine was the power cable, but i had the engineer to sort it
Jul 05, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
Gerry Harvey
Gerry Harvey
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
