Question about Pioneer VSX-521-K 5.1 Channel A/V Receiver
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
I have the system completely installed and all cables and plugs are secured and plugged in. I have a smart Blu-ray player(Phillips bdp-2175) and a Motorola DVR for Comcast cable. I also have a Belkin Song Stream Bluetooth receiver plugged into my Pioneer receiver. Both, the Blu-ray player and the Comcast DVR are going through the Pioneer Receiver via HDMI cables and one HDMI cable going from the Pioneer receiver to the TV(Vizio E601i-A3) My Comcast cable Motorola DVR is working perfectly going through the Pioneer Receiver, but I cannot get the Phillips Blu-ray player to pair with the Pioneer Receiver, as I get "no signal" message on TV and HDMI is blinking on the front panel of the Pioneer Receiver. I have tried everything I can think of including unplugging and resetting all components, hard resetting all components, trying different settings in the Pioneer and Phillips setup menus. I know the Blu-ray player is working fine with the TV, because I can bypass the Pioneer receiver and run the HDMI directly to the TV and it works fine. The handshake between the Blu-ray player and the Pioneer receiver is my problem. Any suggestions would be greatly appreciated, as I would love to watch a great Blu-ray movie using my new Bose Acoustimass 6 series III Surround sound system. Thank You!
Posted by Robert Buss on
  • Robert Buss May 04, 2014
    Almost forgot! when I switch the Pioneer Receiver to BD(Where Phillips player is connected) and power on the Blu-ray player, the Pioneer receiver front panel has a red light come on labeled HDMI and the HDMI displayed stops blinking. At the same time, the TV screen brings up the Phillips start screen, but a few seconds later, it goes black again saying "no signal", the red HDMI light goes off of the front of the Pioneer receiver and the HDMI on the display starts blinking again.
1Bigchicken
    Scholar:
    New Friend:
  • 54 Answers
Have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
Posted on May 11, 2014
1 Related Answer
scottscholz
  • 120 Answers
SOURCE: Problems with Sharp Blu Ray Player "copy protected signal"
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
Posted on May 20, 2009
The unit will not power up, it is plugged in to a live outlet. Is there a fuse or a reset?
FAQ: Blu-Ray, DVD and DVR / DVD Recorder ... - Toshiba
https://support.toshiba.com/support/viewContentDetail?contentId...
ToshibaApr 9, 2013 - Blu-Ray Player does not respond to some operating commands during playback; Random lock up of Blu-ray player occurring after the unit is turned off ...Check to make sure that the unit is plugged in securely to the power source (outlet,... Toshiba BD-Live enabled players offer the ability to allow different ...
PDF]BDP - S185 / BX18 - Sonyhttps://docs.sony.com/release/BDPS185_BX18.pdfSony Corporationray Disc/DVD player is harmful to eyes, do not attempt to disassemble ... Install thisunit so that the AC power cord can be ... Connect the equipment into an outlet on a circuit ... type plug has two blades and a third grounding ... Do not turn up the volume while listening to a ... protection systems used in both Blu-ray Disc™ and.[PDF]Blu-ray Disc™ / DVD Player - Manuals, Specs & Warrantyhttps://docs.sony.com/.../BDPS1200_BX120_S3200_B...Sony CorporationDVD Player. Operating ... in this Blu-ray Disc/DVD player is harmful to eyes, do not ...Install this unit so that the AC adaptor can be unplugged ... Connect the equipment into an outlet on a ... If the provided plug does not fit into your outlet .... Do not turn upthe volume while listening to a .... BD-Live™, BONUSVIEW™, and the.[PDF]Smart 3D Blu-ray Disc™ / DVD Player with Built-in .
Jan 11, 2016 | Televison & Video
How can a make multiregion my sony bdp s2500
Sony BDP S1200 - Region hack ?. - VideoHelp Forum
forum.videohelp.com > Forum > Hardware > DVD & Blu-ray Players
Dec 14, 2014 - 13 posts - ‎7 authors
Hi peeps, My old Phillips Blu Ray gave up the ghost this week, ... especially bluray players. usually only the dvd side can be made region free. Sony BDP-S2500
Nov 30, 2015
Jan 26, 2010
Samsung BD-P2500 - All Regions Hack Required
Dec 1, 2008
More results from forum.videohelp.com
Multiregion sony bdp s2500 - Fixya
www.fixya.com/support/t25991992-multiregion_sony_bdp_s2500
3 hours ago - multiregion sony bdp s2500 - Sony DVD & Blu-Ray Players question. ... How can a make multiregion my sony bdp s2500 Multiregion. Dec 03 ...
Sony BDP-S580 multi region DVD hack with URC-3440 ' AVForu
Dec 03, 2015 | Sony Televison & Video
What are the codes to connect a Phillips smart TV remote to a BDP s5200 blu ray player?
If your Phillips remote is programmable, you can search for a code that will work with your BDP Blu-Ray player. If your search produces no result, you may have to try another universal remote.
Jul 21, 2015 | Televison & Video
NEED TO EJECT MY DVD USING THE TIME WARNER UNIVERSAL CONTROL. WHICH BUTTON IS IT?
Universal Remote codes for Blu-ray Players - AVS Forum ' Home ...
www.avsforum.com/...control.../1297068-universal-remote-codes-blu-ra...
Dec 10, 2010 - 12 posts - ‎7 authors
Brand new Sony bdp-bx59 Blu ray player with a Rogers Atlas PVR remote, Model 1056B01 ... A button, my Samsung DVD/VCR remote's Power button in there on the ... it just means the machine you are trying to control either came out after .... I have the same Blu Ray and Time Warner remote as you do.
Eject key unavailable on sony blu ray bdp-s3200 - Fixya
www.fixya.com/.../t24026716-eject_key_unavailable_sony_blu_ray_bd...
Apr 6, 2014 - eject key unavailable on sony blu ray bdp-s3200 disk tray wont open -Sony BDP-S3200 ... Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 4 Answers .... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? ... Sony BDP-S300 tray open while updating, stuck here.
How can I fix my Sony Blu-Ray player BDP-S3200 with the ...
www.fixya.com/.../t24578583-fix_sony_blu_ray_player_bdp_s3200_eje...
Jul 27, 2010 - Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 1 Answer .... SOURCE: Sony BDP-S300 won't play any Blu Ray discs. Sounds ... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? Dec 28 ...My player cant eject disc; it say '' eject key is not available this time''.
Remote codes - Comcast Help and Support Forums
Nov 23, 2013 | Sony BDP-S300 Blu-Ray Disc Player
Sony BDP flashes wait .... unplug plug back in after 5 minutes will not reset, still flashes wait, there is no disc in the tray
I had the same problem and finally got it to work.
Unplug it for five minutes.
Plug it in but DO NOT touch any buttons for one minute.
It should turn on normally.
Jan 31, 2013 | Sony BDP-S570 Blu-Ray Player
My sony BDP-s550 has a green tint to all dvds we watch. I already tried resetting to the factory settings with no success.
Just another thing to check that may take a few seconds.. Are you using componet video cables on this dvd player? If you are, check that all 3 video cables are plugged in, you may even want to unplug the cables and plug them back in. If you have a spare componet cable try that as well to make sure it is not a cable issue. I have been to many homes where just 1 of the 3 componet cables was just unseated or had a broken cable.
Mar 08, 2011 | Sony BDP-S550 Blu-Ray Player
HDMI not working Sony BDP-S350
plug the sony player into your home network via a network cable ( should be a network port ( RJ45 port ) on the back of it and then update the firmware - unless its already the latest version, if it is then post back with any error messages or whats happening exactly when you try to select HDMI or is it greyed out ?
Jun 02, 2009 | Sony BDP-S350 Blu-Ray Player
BLue ray DVD player
I am not sure about the Sony BDP-S300 Blu-Ray Disc Player: But the Samsung BD-P1000 Blu-Ray Disc Player requires HDMI cable
to give the best resolution (1080p) possible that the TV set is able
to support. Hope this helps.
[email protected]
Nov 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Pioneer VSX-521-K 5.1 Channel A/V Receiver Logo
258 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
