Question about Kenmore Dryers
What does this error mean dryer has error f-01?
Posted by Jessica Miller on
TorchToolman
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
The "F1" error means that the dryer's thermistor failed and needs to be replaced. Make sure you check the dryer vent for clogs before installing the new part.
Posted on May 26, 2014
What does code F 01 mean
For a start, google "Kenmore Dryer Model xxxxx error code F 01"
where xxxxx is the model of your dryer. Sift through the hits for an answer.
Pete
Sep 28, 2015 | Kenmore Dryers
What does the whirlpool code f-01 E03 mean?
f/01 is an EEPROM error on the main computer. A power glitch may cause this error; unplug washer or disconnect power for 5 minutes..If the computer does not reset unfortunately you are looking at replacing the main computer.
Sep 01, 2014 | Whirlpool Dryers
MAYTAG EPICZ DRYER ERROR CODE F-01
F01 means the main control board or "micro computer" has detected an internal short. Unfortunately, the only way to correct this issue is to replace the control board itself. It's under the top panel in the front right corner.
Dec 05, 2013 | Dryers
Maytag model MEDE500VPO what does the f 01 code mean?
Controller board malfunctioning.
Try looking at the video at
Duet Sport Dryer 2008 Error code 01
If repairs like this are not something you want to attempt, try calling a repairman, particularly if the dryer is under warranty.
Jan 04, 2012 | Dryers
Fault code f-01
The "F-1" error code means a failure occurred with the electronic controls.. This could mean that wires are broken, the electronics shorted out or a manufacturer's default error shut the washer down.
Prevention/Solution: The electronic control panel needs replacement. Find your dryer serial number and search for the part online.
This is a lengthy job that usually requires a repairman unless you have dealt with and repaired dryers before. If your dryer was purchased within the past couple of years, the dryer could be covered under the warranty.
Hope this helps (remember to rate this free answer).
Jun 02, 2011 | Hotpoint Washing Machines
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
Dryers Logo
148 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
