I have an LG DLEX7177RM electric dryer. There are 5 heat settings: High, Medium High, Medium, Low, Ultra Low. The dryer doesn't heat on the Low setting. I don't think Ultra Low works either. The other heat settings work fine.
SOURCE: LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
SOURCE: Dryer runs but no heat
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
