My merit dma mobility scooter is not charging when connected to the mains, the batteries charge ok when standard 12v battery charger is usedb, when everything is connected the on board charger iappezrs to be outputtin 24v can you help please
SOURCE: Require instruction book for DMA Merits
PRIDE pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Traveler Elite Plus: Unit will
I've been a tech for years, and sometimes any assumption that something is "good" can be the one thing that trips you up for awhile. This is a really tough problem, since you've done about all you can to solve it. Here's what I suspect...either the batteries don't have the same current capacity as the old ones, or they could be underengineered, or even defective. I've bought car batteries, on two occasions, that were bad, even though they swore they were good.
You'll have to get someone to test them for their load capacity, that's the only thing I can figure at this point. Not sure who will have this capability- you might call around to some service shops and see if they can help, or know someone who can.
If all the connections are good, and the motor is new, there just leaves the harness itself and the batteries to suspect.
Ensure the batteries are good, and then you will have to check the cables for load capability and integrity.
Good luck, and hope this helps.
SOURCE: type of charger needed for a merit D.M.A mobility scooter
http://www.easymobilityco.com/merits_mobility_scooters.htm
SOURCE: i have got a merits mobility scooter when i try
are you placing the battery to the right terminals .. cause if positive is on positve then it wont blow up the fuse .. cahck and confirm
i hope this helps u
SOURCE: Hi, fitted my scooter with two brand new 40 amp hr
What type and what voltage were the old batteries removed from the scooter?
Testimonial: "Thank you for the help, - the link didn't work but i'm slowly getting to understand things now."
