Question about Emerson MW8107WA Microwave Oven
How do i change a bashboard bulb on heater control on a iveco daily
Microwave light socket shorted out
every thing all right accept working heater both heater tube doesn't light or no power on it
Nov 14, 2013 | Amana Radarange Microwave Oven
How do i change the bulb on ag821azh microwave x2
follow this steps and use the VOM for fix it. God bless you
Light Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 19, 2013 | Microwave Ovens
Lights on bottom don't work. Sockets fell apart and vent fan now does not work. A bulb blew out , then all of this happened.
We see and repair this a lot. The problem is on the control board, which we regularly repair for $39.95 nationwide.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
We'd also recommend buying top-quality bulbs.
They can blow if subjected to vibration such as door slamming or a weak floor, or electrical fluctuation, especially if they are cheap bulbs or they are left on all night.
Instead of having the board repaired, you can order a new control circuit board / smart board if that's economical, and since your sockets are bad, they will need to be replaced, too.
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your
favorites.
There's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you're changing the board yourself, you'll need to detach the keypad connector:
Some connectors will have a lock.
Dec 27, 2012 | Microwave Ovens
I was changing the bulb and the bulb burst as I turned it. I thought I heard a pop. When I looked at the keypad and clock they were dead, blank no indication of any electricity. I then saw the warning that...
You may get lucky and find that one of several fuses has blown, but I would suspect your board needs repair.
There should be a mini-manual hidden behind the controller or the grille. It's very helpful in locating and checking parts.
But we see (and repair) this a lot. The problem is most often on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year repair guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
If you prefer, you can purchase a new control circuit board from the Pros here. They're our favorite supplier.
Nov 21, 2010 | Whirlpool GH5184XPQ Microwave Oven
Surface lightbulbs changed but now can't turn off lights.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or two.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
While changing nightlight bulb, it twisted off and short circuite
In all probability, the short took out the relay on the control board and the control board will need to be replaced.
I hope that helps.
Mar 16, 2010 | GE Microwave Ovens
HOW TO CHALGE LIGHT BULB
disconnect the oven from power supply. If the lamp of your microwave is in the most common location, you will need to open the oven by unscrewing the screws on the rear. You will see the lamp behind the control panel. remove and replace the bulb
Jan 12, 2010 | Goldstar MA-1011 Microwave Oven
Bulb blown on Russell Hobbs CJ/AL28 microwave
Just open the top cover and find the location of the bulb , it may be in the right side near the control panel. Remove the bulb and get a similar bulb with the same rating from any electrical shop and fix it
May 25, 2009 | Microwave Ovens
GE Spacemaker XL1400 Microwave - Lights wont cut off
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too, due to a shorted relay.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Aug 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Emerson MW8107WA Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
