My washing machine model AW-SD130S showing error code E71, what does it mean
Posted by Maggie on
Ahtsham Joyia
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Toshiba AW-DC1700WUB Washing Machine Error e71
Posted on Dec 02, 2016
naveed
    New Friend:
E71 is the PC 2 problem not a pressue switch or drain water issue as explained by techy. Please replace PCB . I dont know which IC has to replaced from PC 2 .
Posted on Oct 21, 2014
ddd228
    Sergeant:
  • 311 Answers
Un plug machine to "reset". Then call service person.
Posted on May 04, 2014
3 Related Answers
syd_2811
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Posted on Aug 28, 2011
Anonymous
  • 45 Answers
SOURCE: error code on washing machie
The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too.
Posted on Jan 03, 2008
micmacmac
  • 26 Answers
SOURCE: Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Posted on Nov 19, 2008
Hello sir my Toshiba washing machine model no. AW-AD1500WUBB error Ed
That code means extended drain. It is taking too long to empty the water. Check the pump and drain system for items that may be plugging it.
Aug 04, 2018 | Washing Machines
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
My toshiba washing machine model AW-80VE(w).how can i reset the program of the machin? when i turn on it error E71.
Hello!
E 71 is an error of a temperature sensor.
Most likely, there the contact was interrupted or there was a short circuit of the sensor and / or circuit.
May 16, 2017 | Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Toshiba AW-SD150S error E71 what does it mean?
my washer Toshiba AW-SD150S washer can not funtion .it will come out error code E71.some body can tell me what is the problem
Jan 26, 2013 | Cell Phones
My AW-1190S toshiba washing machine was showing error code E2-3
My Toshiba aw1190s shows error code E21. What the problem.. Tq..
Nov 22, 2012 | Washing Machines
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
Nov 13, 2010 | Washing Machines
Washing Machines Logo
1,136 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
