SHOW ERROR COD C6000 AND CAN NOT READY FOR COPY
Replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
SOURCE: HOW CAN I RESOLVE ERROR c6000 in fs 1118
This might take some doing reseting the fs 1118 but it can be done if the fuser only got hit by a powersurge or overheated due to paperjam by the fuser...
press system menu/counter
select service settings via up and down cursor keys
now while pressing start key and # key press enter
then select maintenance mode by using the up down cursor key
press enter
enter 163 and then restart the copier...
sometimes you wont even be able to get to the service mode...
open the front of the copier and then execute the steps... the front meaning the area where you the toner is located...
trying keeping it open and do the steps...
if that fails then open it take out the toner drum cartridge and then put it back in...
then do the steps...
if it still doesn't take try it a couple more times...
if it still doesn't take.. buy a new fuser...
but it should take... it just takes a little experimentation...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: error code c6400 on fs-1118
fuser temperature over /under u need service engineer to reset it
SOURCE: KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
