Question about Moen Plumbing
How do i install a moen stem replacement kit part 97479?
Kingsley two handle lavatory faucet
torn up
    New Friend:
    Problem Solver:
  • 15 Answers
Make sure you turn the stop under the cabinet off use an allen wrench to take the handle off pull the keeper off the old cartridge pull the old cartridge out and make sure you put stem grease on the o-rings before installing the new cartridge or you will cutt the o-rings and ruin your new cartridge. put you keeper back in and reinstall your handle. turn your water valve back on underneath and enjoy.
Posted on Oct 26, 2014
5 Related Answers
arealplumber
Better Plumbing
  • 33 Answers
SOURCE: Stem Valve is frozen on my 3175 Legend.
Here is a possible solution for you. First go out and buy a Moen cartridge puller tool like this:
Next follow these steps:
  1. Turn off the water to the valve.
  2. Install puller and rotate cartridge several times.
  3. Gently pull on cartridge while slowly turning.
This should work. If the center of the valve pulls out continue below with these suggestions:
  1. Remove center piece from tool.
  2. Place the brass feral to the end of the tool as shown.
  3. Insert this part of the tool into the valve all the way as far as it can go.
  4. Turn the tool until you hear a click or tool feels like it turns the valve.
  5. Pull on the tool gently while turning.
This should get the job done.
Also here is some information for you about your valve:
Moen 3175
Hope this helps and please rate this suggestion.
Posted on Dec 08, 2008
Anonymous
  • 51 Answers
SOURCE: my moen faucet leaks around the stem when i lift
Maybe needs a washer if it has one if not think it has worn out.
Posted on Jun 10, 2009
chadd
  • 60 Answers
SOURCE: Moen T910 Kingsley two handle, whirlpool tub
if you remove the hot water handle on the faucet you can adjust the stop. if it is a newer faucet it has a built in scold guard. the directions should tell you which direction to move the stop to get hotter water
Posted on Oct 22, 2009
motor1258
Mike Butler
  • 6674 Answers
SOURCE: how do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Posted on Jan 22, 2010
Randy Marshall
  • 349 Answers
SOURCE: How do I install the Moen 10790 Lavatory Faucet
This in link below had a detailed instruction on how to install your drain.
http://www.ehow.com/how_2342611_install-sink-pop-up-drain.html
This link below has a parts view of how it goes together. If you will look the waste seat will be the peice that will go in your sink up top and everything esle underneath.
http://www.plumbersurplus.com/pdf/02535.pdf
Posted on Jun 20, 2010
My Moen exacttemp thermostatic shower goes to either hot or cold - can't figure out how to control the temp. This was just installed and the installer didn't provide instructions.
Your meon shower has a carriage the handle is attached to, sounds like there might be something in it or the carriages is warn and needs replacing.
Apr 17, 2011 | Moen TL3450/3600/3371 Kingsley Handle Tub...
I have a handle that came off a Moen Villeta 2 handle bathroom faucet. It is not obvious, no set screw etc., of how to attach the handle. Also, the stem that the handle attaches to, seems to have dropped...
Sorry to read about your problem, I hope this helps you out.
under the moen symbol is a set screw
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Moen & Villeta Two Handle Lavatory Faucet
I can't get the faucet to not move from side to side after it is tightened donw on the granite vanity top. The base is tight and does not move, but the faucet part still moves a little. How can this be...
The faucet should have come with a rubber gasket which goes between the faucet body and the granite top. Make sure it's properly aligned and has not slipped out of place. Be carefull when tightening the faucet to the granite, since granite is easily cracked.
Aug 10, 2010 | Moen 6102AZ Kingsley Single Handle...
I have a loose handle on my Moen two hanlde lavatory faucet and i can't find any set screw to tighten it . How to tighten the handle to the faucet stem?
Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
If you can't see a set screw it may have a screw in handle on top.
May 03, 2010 | Moen & Villeta Two Handle Lavatory Faucet
How do I fix a dripping MOEN T4572 lavatory faucet
No charge.
Jan 18, 2010 | Moen Monticello Single-Handle Kitchen...
Moen T910 Kingsley two handle, whirlpool tub faucet. The hot water handle only puts out lukewarm water. The water heater is turned up and all the other faucets in the house put out scalding hot water.
Oct 22, 2009 | Moen T910 Kingsley Deck Mount Whirlpool...
Moen Tub Filler Can't Remove Spout
It should lift off gently twist as you lift maybe tap spout lightly back and forth with a rubber mallet
Oct 14, 2009 | Moen Kingsley Two Handle Roman Tub Faucet...
Need to replace handle adapter kit on a Moen monticello two handle lavatory faucet
Lowes might carry them but i know a plumbing supply house does for sure. Take center caps off hot and cold handls, then screws everything else should pull right off.
Sep 10, 2009 | Moen & Monticello& Two Handle Lavatory...
Plumbing Logo
497 people viewed this question
Top Moen Plumbing Experts
john h
Bruce Robin
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
