The freezer drawer does not pull out far enough to remove the baskets. It appears there is another two inches or more that the rail slides should extend but it stops short. Manual directions state to remove the door you have to remove the basket to access the 10mm hex screws but since the bottom basket can't be removed it's not possible.
SOURCE: removing doors from a samsung rsg 5 dumh american fridge freezer
doors are removable. wiring to the door is plug and socket
SOURCE: what is red basket light on for says filter above it
The red and green basket lights are your filter status. it works on a timer from when the fridge is new or reset it. when you change a filter or just want to get rid of the rid light and make it green again, press and hold the ice type / change filter button for about 5 seconds. it will then go back to green. It will stay green for 6 months from that time when it will go red again.
SOURCE: Door Removal
If you don't have the manual, go to Samsung's website and download the manual. It explains how to remove and adjust the doors and bottom drawer.
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
SOURCE: I have a Samsung fridge model RF265AB. We can her
The problem is on your fan motor. This fan will automatically off when the door open. It has the switch that activated by the door. Please check and fix your fan, since it work with strong noise. The problem is usually on its bearing.
Regards
1 Open drawer to the fully out position.
2 Remove upper and lower baskets.
3 Remove screws one in each rail marked on side of rail.
4 Lift the front of the drawer up to remove the drawer.
5 Set the drawer on a soft surface to prevent scratching the
finish. If you have other questions please ask, Thanks Sea Breeze
