Jabra BT350 Bluetooth Headset Headset Logo
Question about Jabra BT350 Bluetooth Headset Headset
How to Replace a Bluetooth Battery wep170 - Jabra BT350 Bluetooth Headset Headset
How to get my pass code back on my ipad
I assume you mean the code for the headset?
The default is "0000" when pairing.
1.
Ensure the headset is off (see Turning headset on/off section).
2. Press and hold Power until you see a solid blue light (approximately 8
seconds), then release* (see Fig. 3).
3. Set your Bluetooth phone to "discover" the headset by following your phone's
instruction guide. Typically, the steps involve going to a "setup", "connect", or
"Bluetooth" menu on your phone and then selecting the option to "discover" a
Bluetooth device.
4. Your phone will find the "Samsung WEP170" headset and ask if you want to pair with
it. Confirm this by pressing "yes" or "ok".
5. Enter passkey or PIN4 = 0000 (4 zeros), then press "yes" or "ok".
Manual link
http://downloadcenter.samsung.com/content/UM/200906/20090609223230593/WEP170_ug.pdf
I bought a samsung bluetooth wep-170 for my samsung sgh t4 01g phone and i enabled bluetooth but it says no bluetooth device found the guy said it would work can u please help me
You need to put the headset into pairing mode for the phone to be able to find it. There are some instructions on this page:
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=22&PG_ID=557&PROD_SUB_ID=735&PROD_ID=786&AT_ID=80738
Please follow these, hopefully they will help solve your problem
Tom tom needs a password to link to wep 170 but i dont know it
the default code for a bluetooth device is usually 0000 (four zeros) or try 1234 good luck
PASS CODE FOR A Bluetooth
Hey dude,
U dont need to search for the pass keycode. It is the key u put on. Put on the same code on bluetooth which u have put in ur mobile/PS3.
moz-screenshot-4.jpgSend me a feedback. And Rate me if my solution is helpful !
1helpful
2answers
Ear hook
You can find the replacement ear hook for this bluetooth on EBAY.COM. The one I found was going for $.39, Buy it now price $1.00.
14helpful
2answers
Passcode for Samsung WEP170
must start with headset turned off.
1) turn on headset and keep your finger pressed until the blue light stays on
2) now let your phone search for the device. when it does select it
3) the pin is 0,0,0,0
4) then it should be matched
Soft, rubber like piece cover speaker on Samsung WEP170 Bluetooth
I bought a pair of Sony headphones for my MP3 player, they came with three sets of rubber covers for the bud part of the head phone.
I have the WEP 170 also but didn't like how it fit in my ear, so I took one of the Sony bud cusions and replaced it with the one on the WEP, works great and even helps to cancel out noise.
Hope this helps
RoToHakr
2answers
WEP170 headset
I found out that not all Samsung bluetooth phones are compatible with this WEP 170 Bluetooth handset. I called my carrier (AT & T) and they informed me that my mobile phone (also a Samsung SGH 700 series) might not work. I'd advise checking with your carrier to see if they can help clear up any problems.
Top Jabra Radio Communications Experts
David Shaub
Muzahura Frank
George Etukudo
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
