HP Hewlett Packard Pavilion A6200N  PC Desktop Logo
A
Anonymous Posted on May 04, 2014
How to remove password from hp computer - HP Hewlett Packard Pavilion A6200N PC Desktop
matsak spiros
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • HP Expert 147 Answers
  • Posted on Apr 16, 2017
matsak spiros
HP Expert
Level 2:
New Friend:
Cheetah:
Answers
147
Questions
0
Helped
32265
Points
493
You must clear the cmos. Unlplug from power socket open the desktop and search for a 3 pin socket that sort 1 with 2 or 2 with 3 and naming cmos clear. Sort with other pin if you see sort 1 with 2 then pull the jumper and sort 2 with 3 for few seconds 2 or 3. Then pull again the jumper and sort the old one selection. You can remove and the battery (c2032 usually).
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
How do I get back into my computer.
if you know how to restore then just undo the restore and put it back as it was. then when it ask you for your password put it in and if it works keep note of it then do the restore to a previous time.
2helpful
How to reset hp elitebook 8460p bios password?
Generally, there are two ways to reset forgotten HP BIOS password. One is forcing BIOS/CMOS to reset itself to its stored defaults by removing all power to it. The other is to use a program to either locate or identify the password and reveal it to you or erasing the password entirely.
And the most easiest and convenient method for erasing dynamic BIOS/CMOS settings is to remove battery directly from the motherboard. It applies to most motherboards besides HP Elitebook BIOS. At this moment, HP Elitebook based on UEFI Bios provides a tool to reset BIOS password specially - HP SpareKey.
How to reset BIOS password with SpareKey?
1. Before forgot BIOS password, you have set answers to three predetermined personal identification questions.
Write down the answers to these questions and put them in a safe place, away from the computer, so that you can always access them.
2. When you cannot remember the password to access the BIOS on your computer, turn on the computer and immediately press the ESC key to display the Startup Menu. And then press the F7 key.
3. HP SpareKey wizard pops up and prompts you for the answers to the three personal identification questions. If you successfully answer the questions, you are granted access and you can reset the password.
If you do not answer the questions correctly in the three attempts, you will be locked out of your computer. And then you must contact HP for assistance.
Note: HP SpareKey cannot help you recover a Windows 7 or Vista administrator account password. It is intended solely to recover system-level passwords.
http://www.isunshare.com/windows-7-password/reset-hp-elitebook-password.html
I don't remember the Power On Password in my computer. Is there a System to remove this Power on Password?
If your system is prompting you for the Power-On Password there are a few things you can try.
First - remove the Battery and the Power Cord. Next remove the RTC battery. You can find instructions for how to remove the RTC battery from the user guide here: http://h10032.www1.hp.com/ctg/Manual/c00753552.pdf it is on Page 111. Leave all of the batteries and power off/unhooked from the computer. Next, press and hold the power button for at least 30 seconds while there are no batteries or power cables attached. Then allow the computer to sit for at least 5 minutes without the power sources. Finally - replace the RTC battery and then plug in the power cable. DO NOT PUT BACK IN THE MAIN BATTERY YET. Power the computer on and see if the password has been blanked out.
If the power reset fixes the password, then you can put back in the main battery and go about using the computer.
If the power reset does not fix the Power on Password - you will need to contact an HP authorized repair center to get it fixed. This is not a cheap option, but it may be the only way to remove the password. To get started with a repair with HP you can call: 866-234-1377.
I hope this information helps you out!
6helpful
6answers
I forgot my BIOS password and i can't access it becos i don't know the password.
HP Spare Key can be used to reset BIOS password. It is provided by HP Corporation. So when you forgot BIOS password on HP computer, just download it and get perfect BIOS password reset.
How to reset HP bios password with Spare Key or other ways?
Please refer to reset HP Elitebook password. In this passage, you also can learn how to reset Windows administrator password easily.
13helpful
3answers
How to remove bios administrator password for hp elitebook 6930p notebook pls help me
Actually, if you want to remove BIOS password on HP laptop or PC, there is an effective tool Spare Key available for you. It is provided by HP Corporation. At the same time, if you prepare to remove HP administrator password, you can have a try to use Windows Password Genius. Choose appropriate version based on your computer operating system, Windows Password Genius Standard/Professional/Advanced.
11helpful
5answers
Forgot my administrator password
Hack HP Computer Password ' Erase HP Desktop / Laptop Password Without Being a Hacker
  • In my received E-mail that people ask to recover lost PC password, a quarter of people are using HP computers. So I prepare this tutorial specially for these HP users.
2helpful
2answers
How i can move delete bios password on laptop hp nx 63 25or can i get original password
it is not possible to delete the BIOS password set by the user. However, you can try remove and reseating the CMOS battery of the computer. This will delete the BIOS password sometimes. You can refer the manual below to remove reseat the CMOS battery.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00715299/c00715299.pdf
Refer page no:116
i hope this helps u. If not, then the only option is to contact HP or any local computer service center
2helpful
3answers
EliteBook 8530p bios password
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
