Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
Bose sound dock series ii does not advance music tracks
5 Related Answers
Anonymous
  • 20 Answers
SOURCE: Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Posted on Dec 11, 2008
Anonymous
  • 71 Answers
SOURCE: our sound dock does not charge our ipod touch 2nd
The original SoundDock will not charge the iPod touch 2nd gen, or the iPhone 3G, or the new nano either. This is because Apple changed the way their new iPod products charge. (via USB only now)
There is 1 solution- Call Bose tech support. They can replace the 30 pin metal connector for a new one that will charge this. If this is not under warranty, it will cost $99, but it's worth it. New 1 year warranty, and compatibility with all iPods (except much older- non-clickwheel iPods)
Posted on Jun 21, 2009
Mikael Wahlgren
  • 17 Answers
SOURCE: bose dock station tray is loose
You can get a new connector (or a replacement PCB if you are not very good at soldering) at http://www.chargeconverter.com/shop/connector.htm?connbose.htm
Posted on Mar 29, 2010
woodzowl307
  • 667 Answers
SOURCE: Just setting up my bose ipod dock for the first
Sounds as you have a broken unit that will need to be serviced.www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/warranty_center/index.jsp
Posted on May 25, 2010
vetteman3002
Rodney Clark
  • 2299 Answers
SOURCE: My I Pod Nano Radio
Is the connector on the bottom of the ipod making good connection when it is plugged in? Try moving the ipod around a little.
Posted on Sep 21, 2010
Can I make a USB port out of my laptop plug into an AC input on the Bose Series II Sound Dock so I can play music from my laptop?
What you want to do won;t work and can damage your laptop and or Bose.
If you want to play sounds from your laptop to your Bose, you need to plug an audio lead from the headphone socket on your laptop and connect the other end of this audio lead into the audio input on your Bose Sound Deck (if it has an Aux input).
Dec 29, 2011 | Bose Audio Players & Recorders
Bose sounddock seriesII remote will not navigate playlist
EIther the remote is faulty or a broken comms pin on docking connector. www.invebo.com will rpelace the dock connector for you for about 30 Euros.
Apr 16, 2010 | Apple Bose SoundDock Series II Digital...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Popping noise and cutting volume on Iphone
i have the same problem. I started after an iphone software update.
Jun 15, 2009 | Apple Bose SoundDock Series II Digital...
Does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
May 31, 2009 | Bose SoundDock digital music system...
I have an ipod touch 8G I purchased a Bose soundock II. The sound is great but the remote only controls the volume. I cannot change tracks, move through playlists and when I hit the off button on the Bose...
Bothe the docking station and the remote are useless I recommend you buy a universal remote control.For the Ipod switching off-it does'nt switch off reason being it has it's own battery and does not depend on the electrical power of the docking station.
Mar 06, 2009 | Apple Bose SoundDock Series II Digital...
Dec 09, 2008 | Bose SoundDock digital music system...
Bose Sounddock - Speakers have a loud hiss at low song volume
Here is how I fixed the hissing noise in my Soundock;
--Pull the bottom plate off (It is attached by 4 screws)
--There is a green motherboard with 2 ribbonwires. .
--One of the ribbonwires (the one the mounts the ribbon vertically) had loosened up.
--Use a tweezers to pop it back into place and that noise will disappear.
This is a design flaw, as the action of inserting/removing your ipod, coupled with the action of setting your sound dock down will work this ribbon loose.
May 30, 2008 | Bose SoundDock Digital Music System for...
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
44 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
