I have an older hitachi plasma tv and after my nephew was over this last week, it is zoomed in to where you can't see what channel you're watching. I need help fixing this. We had a tech come out a few years ago to help fix it when we switched service providers, but it's back and I can't figure out how to fix it
Press the settings or menu button on your remote. There should be an option for aspect ratio. Set it to widescreen or 16:9
Posted on Dec 15, 2017
SOURCE: Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Posted on Jun 14, 2007
SOURCE: hitachi SP-43W magic focus
remove front grill assy to front of the internal pc boards.on your left side ther is a blue rest button mounted on the convergence board this is the eprom rest ,unless yuo know and have the service manual do not rest the eprom at this time. look at your front control panel to see if thers a small hloe and if so you need a thin rod to acitvate the button inside. again the service book will help /
Posted on Aug 22, 2007
SOURCE: My TV is on a sort of permenate zoom.
hello, my 1 yr. old just last nite was pressing buttons on the front of my RCA 52" and i saw something pop up in the left corner that said zoom. i have not found anything that will unzoom it but i have found something to help. Go into the menu and go to picture. then to the advance settings and choose the automatic preference. it will fix it depending usually on the programming. Myabe someone will know how to turn off the zoom!
Posted on Jan 11, 2008
SOURCE: TV picture shaking!!!
It sounds like the Hyper board is begining to fail....Does the menu shake too?
SOURCE: TV will not turn on
Good Morning Chris,
OK, first of all lets unplug the TV and wait 15 minutes for the High Voltage to discharge.
Remove the back and follow the power cord to the power supply. Somewhere around there you should find a fuse. (there may be more than one) get a bright light to look inside and try to find as many fuses as you can. Remove each fuse one at a time and check them with an ohm meter.
If you don't get a good solid reading on any of them replace the fuse or fuses with the exact same rating. Even if you get a reading and the display is jumping around and will not stablize, replace the fuse. Usually a good fuse taken out of the circuit will display a good steady reading on the meter.
I hope this solves your problem.
Have a great day!
Posted on Mar 26, 2009
