Magic Chef MCBC580DBT will not run. Display shows 67 degrees. Does not cool at all.
SOURCE: Re: Magic Chef
If the compressor is running but the fridge is not cooling, the gas may have leaked out of the system or the compressor is inefficient. The only way to know for sure is to connect a set of gauges to the system. You will need to call in a Refrigeration Mechanic.
Posted on Nov 03, 2007
SOURCE: Power Consumption - Magic Chef Wine Cooler
The unit will draw between 6 and 12 amps on start up and running it should use less than 1.6 amps. The start up amps will increase with age. Funny how that works the same for people as it does for machines. I hope this will FixYa. Please dont forget to rate. Mike
Posted on Sep 24, 2008
SOURCE: Magic Chef MCWC8DSCT Wine Cooler
I had the same problem. I fixed the problem by replacing the main cooling fan that is mounted over the electrothermal cooling unit.. Fan can be ordered from RepairClinic.com.
Posted on Sep 02, 2009
SOURCE: The magic chef wine cooler was clicking now will not get cool .
its your ptc relay.its a very simple fix.to the left of the compressor is a plastic cover with 1 screw.take it off.youll see a small box on top with 1 wire going to it.wiggle it off.pulls straight out left of compressor.go to repairclinic.com..type in part #1206838.its about a $27.00 fix. mines been running fine since.hope this helps
Posted on Aug 07, 2010
SOURCE: Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
May 08, 2014 | Magic Chef Refrigerator Electronic...
Feb 27, 2013 | Magic Chef MCWC30MCG Compact Wine Cooler
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Feb 16, 2012 | Magic Chef Refrigerators
Aug 14, 2011 | Magic Chef Refrigerators
Mar 06, 2011 | Magic Chef Refrigerators
Aug 09, 2010 | Magic Chef Refrigerators
Jun 27, 2010 | Magic Chef CTB1821AR Top Freezer...
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Mar 01, 2009 | Magic Chef MCBR440 Compact Refrigerator
