I have tried every thing can not seam to reset the controle panel it beeps when i close the door and the two lights come on and then go off about 30 sec. maybe 1min later
SOURCE: Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
SOURCE: blinking lights on control panel
Same issue, machine is about 30 days past waranty. Door switch broke, but of course they (GE repair) do not fix the switch, you have to order the Escutcheon Body (whole panel) to fix ~$350 total.
SOURCE: Heated dry and normal wash flashing, also beeping.
hello mam please check the timer and internal wiring.
SOURCE: GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
SOURCE: GE GLD5560 won't start
Although this post is old, I will help anyone else that is searching for the answer. I too had this problem but after looking at the schematics for this dishwasher, I could see where the problem was.
First, open the door and remove the eight screws that hold the inside cover to the front door on. BE CAREFUL. There are wires attached from the front panel of the door to the inside panel for the soap dispenser.
Close the inside panel by slowly raising it up into its closed position and locking into place.
Looking at the front panel from the inside, there is a black box at the top with a white PLASTIC PIN. This pin activates the "CLOSED" signal to the control unit.
Push and HOLD the white pin DOWN until the system resets.
If this does not work, you may need a new unit which runs about $6.
After reseting the system, raise the front panel slightly and press and hold RESET/START for 5-6 secs.
Now, with a second person holding the inner liner against the machine tightly, I started a cycle and it worked fine.
Unlock the inner panel and slowly lower back down and replace the 8 screws.
It's really very simple 10 min fix. the reason this happens is due to the flawed design of the SWITCH PIN, which is not rigid enough. It tends to move side to side and become stuck.
A better quality PIN assembly would solve this issue for GE forever.
Have fun.
