Question about Samsung CLX-3305FW Color Laser Multifunction Printer
Samsung CLX-3305FW Imaging Unit error
Says install Imaging unit
Posted by dpysh on
LEONARD MCCARTHY
  • 189 Answers
Insufficient information to answer the problem. Try going directly to their web site http://www.samsung.com/us/search/espsearch.us?keyword=CLX-3305FW+ and check the SUPPORT and FREQUENTLY ASKED QUESTIONS section
Posted on May 04, 2014
5 Related Answers
henryher
  • 18 Answers
SOURCE: Invalid Imaging Unit and Toners
Sorry about my last post. I didn't realize that it would be placed unter solutions. BUT I did get a resolution from Samsung. They passed me to the advanced team and they suggested I use a special code they gave me to reset all the machine. As I said before the machine was giving me an error that all the toners and the imaging unit were invalid. Samsung said to try this and if it didn't work they would send me a new (refurb) unit. They said to press in sequence <menu><#><1><9><3><start (b&w)> then when the unit cycles it will ask to imput the country, in my case I entered the US. The machine will then reset itself and all the cartridges and imaging unit should be reset to work. IT WORKED!! The machine said to wait while it re-installs the toners. When it did the red warning light turned off and the printer is working great. Hope this helps.
Posted on Aug 18, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Imaging Unit needs to be Replaced
No, what actually happens is the drum fills up with waste toner and you cannot empty it.
Posted on Jan 11, 2009
SamsuTech
  • 113 Answers
SOURCE: Imaging unit clp300
it is more likly that your OPC Image unit has print more than 25K +/-. that the printer will course the prompt.
press and hold the button of the printer for 5sec and let go. it will print out the supplier info of the printer life spend.
there is no way to reset the OPC count unless you work in Samsung.
Posted on Apr 19, 2010
warpspeed
  • 16 Answers
SOURCE: My Samsung CLX-3175FN is asking
You will have to purchase an new imaging drum. It is the shiny green metallic cylinder in the bottom back of the printer. It is the last piece to come out when you remove the toner waste unit and then all the toners. It sits on the very bottom/back of the toner bay. They are not cheap but do not need to be replaced very often and it will give like new printing after.
Posted on Oct 07, 2010
angelo_mlc
Angelito Rabago
  • 1035 Answers
SOURCE: How to replace the imaging unit for the Samsung
Hi. Here's a link for this printer. There is a guide inside the pdf file on how to replace the imaging unit. Please go to page 69.
Have a good one!
Posted on Oct 30, 2010
Failing to receive a fax it says received in memory but not printing even when I want to print. Could you please help
Dear Barati
The printer may have some error. pl. check on the display of the printer. After clearing the error the received fax will printed.
Thanks.
Mar 16, 2015 | Samsung CLX-3305FW Color Laser...
Removing a error message on a samsung CLX MFDevice
Hello.
Causes :
  • The remaining life of the imaging unit is less than 10% of its life.
  • The remaining life of the imaging unit is less than 0% of its life.
solution:
  • Replace the Imaging unit (Toner). remove the old toner and replace it with a new one, look in the user manual for detailed steps.
Additional help :
if you need further assistance on how to replace the Toner, please give me the Printer's Brand and Model and i will provide you with detailed steps.
Thank you.
Aug 29, 2012 | Samsung CLX-3185FW MFC / All-In-One Color...
Can not find the imaging unit for samsung CLX 3170. Do not know how to fix it. Printer says to to replace it soon.
Please have a look at the links below; each includes a short video to help explain the process. You should order an imaging unit to have on hand for replacement. At the end are included the product number for your consumables. Suggest you find a local supplier or seacrh on-line for a competive price or you can opt to puchase directly from Samsung.
How to replace the imaging unit on CLX-3170FN
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?AT_ID=210811&PROD_ID=1093&PG_ID=-1&PROD_SUB_ID=0
How to redistribute toner
http://www.samsung.com/au/support/howtoguide/supportHowToGuidePopup.do?howto_guide_seq=2632&prd_ia_cd=06010100&map_seq=20418&regDt=20091028182505&page_gb=D&model_name=CLX-3170FN&type_ia_cd=06010000&subtype_ia_cd=06010500&row_index=
What to do when toner is empty on CLX-3170FN
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=41&PG_ID=0&AT_ID=210821&PROD_SUB_ID=0&PROD_ID=1093&EMAIL_ID=41
I could not find information specific to your model on the proper relacements for the imaging unit and toner cartridges; however, I was able to find a statement that the CLX-3170FN and CLX-3175FN are the same printer the main difference is just the colour of the unit. They should therefore use the same imaging unit and toner cartridges which I have listed below:
CLT-M409S Magenta
CLT-C409S Cyan
CLT-K409S Black
CLT-R409 Imaging Unit
CLT-W409 Waste Toner Collector
CLT-Y409S Yellow
Trust this is helpful. Please vote.
Dec 29, 2010 | Samsung CLX-3170FN All-In-One Laser...
Samsung CLX-3175FN printer said "replace imaging unit" so I did. Tragically, it still says "replace imaging unit" and taking the unit out and putting it back in has had no effect. I don't know what to do...
Hello, you can try this:
Press: Menu, #1934, Menu, "Tech Mode " OK, "Data Setup" OK, > x7 to "Clear Counts" OK, "Enter Password [1934]", OK, "Clear Counts [Total Page CNT]", >x3 to "[Imaging Unit]" OK, "Clearing...", back
Dec 29, 2017 | Samsung CLX-3175FN Color Laser All-in-One...
I have a samsung clx-3175 printer telling me to replace the imaging unit I'v done that but it still tels me to replace it ,is there a way to reset it or what solutions do you have?
Log into the service menu Samsung CLX-3175 without a numeric keypad similar to the unit Samsung SCX-4623F/FN:
Consistent set of combinations of "MENU" - "COPY ID" - "LEFT" - "RIGHT" - "MENU" - "BACK"
The unit switches to English, if you installed any other.
In the menu appears TECH MODE.
To enter the reset require a password
1934. The numbers by pressing "LEFT" - "RIGHT",
After each number press the "OK"
Good luck in the reset.
Have any questions, you here http://skit-ltd.narod.ru/
Aug 18, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
How do i fix a transfer belt error on my samsung 3160? where is the transfer belt?
take out the imaging unit(imaging unit is where the toners are put and a green OPC is there).
First open the front cover.
then pull the imaging unit.
after that there will be a delicate transfer belt.
Aug 17, 2009 | Samsung CLX-3160 All-In-One Laser Printer
My samsung clx-3160 colour laser printer does not print very well.all prints are barely neglible and now most times no print or characters appear.I have installed new ink cartridges.Please advise.
If the problem is only with Black output you need to change the Black developer of the Imaging Unit, Else you need to refer to the Authorised Service center. Else you may change the complete imaging unit by yourself.
Jun 29, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
May 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Imaging unit
Is it a genuine Samsung Imaging Unit? The unit is not seeing it as such.
This is the # for it, CLP-R300A
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 08, 2008 | Samsung CLX-2160N All-In-One Printer
Samsung CLX-3305FW Color Laser Multifunction Printer Logo
2,628 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
