Question about Taylor & Digital Scale Lithium Scale
My scale is a sharper image scale. yhe model number is ca902. is it broke if it keeps reading lo battery even after i installed brand new battery?
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Posted on Jun 29, 2009
SOURCE: Scales showing Lo after battery has been replaced
Anytime you have trouble with a Taylor scale - they have a lifetime replacement warranty. You need to call their 800 number and pay for 1 way shipping and they will send you a new one.
Posted on Aug 12, 2009
SOURCE: how do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Posted on Jan 21, 2010
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
Mar 29, 2015 | Conair Weight Watchers® WW78 by Glass...
Mar 04, 2015 | Taylor 7506 Precision Tech Lithium Battery...
Aug 22, 2014 | Health & Beauty
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
Apr 19, 2011 | Homedics Digital Scale
Dec 18, 2010 | Taylor 7506 Glass Lithium Digital Bathroom...
Jan 18, 2018 | Conair Weight Watchers Glass Digital Body...
Feb 12, 2010 | Siltec GS-1 Glass Bathroom Scale
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Aug 17, 2009 | Health-O-Meter Health o Meter BFM588DQ-81...
261 people viewed this question
