Konica Minolta Bizhub C360 Logo
k
kdprinter1 Posted on May 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cyan developer finish in 1 months - Konica Minolta Bizhub C360
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 10, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1911965
Points
11959
Must have used a lot of cyan or a bad cyan image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
No cyan coming out in my Konica Minolta c-224e , what's the cause and please what's the solution. Thanks.
Replace the cyan toner cartridge but more then likely your cyan developer unit is bad or the cyan hopper is not feeding the cyan toner into the cyan developer unit. The hopper is what the toner go into. When you pull the toner out that hatch you see well below it the hopper that is where toner goes before getting into the developer unit.
Cyan ATC sensor failure. Error code 14. I replaced developer and did ATC sensor setup. Still having issue.
Yellow ATC Sensor Failure,Code12
Magenta ATC Sensor Failure,Code13
Cyan ATC Sensor Failure,Code14
The ATC Sensor detects an insufficient amount of developer.
Note
If this failure reoccurs three times successively, an Engine NVRAM value is set preventing further printer use until the Clear Tech Rep Fault (see pg.6-20) is performed.
Troubleshooting Procedure
Step Actions and Questions Yes No 1 Is the problem toner and/or developer empty. Replace the toner or developer. Go to step 2. 2 Is the ATC sensor clean and free of dust, toner or any other contaminates? Go to step3. Clean the ATC sensor. 3 1.Check the ATC sensor wiring harness Yellow=P/J129
Magenta=P/J130 Cyan=P/J131
2.Is the wiring harness or the sensor defective? Replace the ATC Sensor and/or wiring harness. Go to step 4. 4 1.Remove the Rear Cover and RearShield.
2.Measure the voltage at...Yellow=P405B3 Magenta=P405B8 Cyan=P405A10
on the engine control board.
3.Is the voltage between+1 and
+3VDC? Replace the engine control board. Go to step 5. 5 1.Measure the voltage at...Yellow=P405B14 Magenta=P405B11 Cyan=P405A11
2.Is the voltage+5VDC? Replace the engine control board. Go to step 6. 6
1.Measure the voltage at...Yellow=P405B2 Magenta=P405B9 Cyan=P405A9
2.Is the voltage 0VDC? Replace the engine control board.
Go to step7.
7
1.Remove the Imaging Unit Plate cover.
2.Inspect the wiring harness between the engine control board and the developer housing assembly.
3.Is the wiring harness defective? Replace the wiring harness.
Replace the ATC Sensor.
8
Run approximately 10 pages of the solid fill full-page prints for this color to ensure the error is cleared.
Developer cyan c7000 spill
Yes you have to have the Cyan developer unit removed and have the developer changed. Once installed there are certain procedures to follow. If you don't follow the procedures you will be buying another bag of developer and start hole process over again
1helpful
2answers
Canon IR C3200 - Error E000020 0170
Fault connected withdrum/developer,in this case yellow(E.020-0170)
...-0270 is magenta,...0370 cyan and ....0470 black.
2helpful
Instead of Bule print DC12 prints Violet
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
Installing PCU on Ricoh Aficio MP2510.
Hello sir; The procedure little bit difficult, Remove PCU, remove the front cover(two screws), remove the rear bushing by remove one lock ring, remove the front joint, remove the developer hopper cover( 3 hook ) dump the old one out vacuum entire unit ( magnet roller ), fill in new developer, replace hopper cover, after replace PCU and developer you need to do some simulation, #1, press "clear mode" "107" and press hold "clear/stop" for 3 seconds, then touch screen on "copier sp". #2, enter sp3902-9 to1 for black drum unit, sp 3902-10 to 1 for yellow, sp3902-11 to 1 for cyan, sp3902-12 to 1 for magenta, #3, enter 3902-005 for black, 3902-006 for yellow, 3902-007 for cyan, 3902-008 for magenta, set 3902 to 1 for each of these if replaceing developer, press "exit" twice to end the service.
6helpful
Printer displays c-0096 on display
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
4helpful
3answers
Malfunction detected C-0096
Code Item
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
