Question about Maytag Neptune FAV6800AW Top Load Washer
Why does my lid lock keep flashing?
Changed lid lock but having the same problem.
Posted by Patty on
Melissa Martin
    New Friend:
There is a right lid lock and a left lid lock which did you change? The left lid lock is a lock and the reed switch which tells the machine control the lid is closed and can start the cycle.
Posted on May 04, 2014
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
My Whirlpool Cabrio washer wtw555oxwo turns on, lid locks, then the lid lock light starts flashing and the machine does nothing. Just replaced the lid lock, but nothing has changed. Any suggestions?
adjust the lid lock switch?? seems to me that lid lock mech is not moving far enough to properly be sensed by switch
if machine is over 8 months old id suspect rust in lock arm as cause
Jul 22, 2015 | Whirlpool Washing Machines
Fisher paykel GWL15 96200B lid will not lock
Change lid lock its the lowest cost part if not lid lock main PCB
is bad High dollar part I would say it is the lid lock they go bad a lot
on many washers
Jul 02, 2015 | Fisher and Paykel Washing Machines
After pushing start, lid locking light flashes, clicks like it is locking but is not locked and nothing happens but it keeps clicking
Sounds like the lid lock itself is bad, be sure to check the connections at the control board. There should be a tech sheet inside the front panel towards the top left. This can help you check the error codes and wiring diagrams.
Dec 01, 2017 | Maytag Centennial MTW5800TW Top Load...
Simpson washing machine 7.5kg 22s750m
Have the lid lock adjusted and always check that the bowl load is balanced. What you have is the machine is reading the lid as open and the spin will not occur until the lid lock reads closed.
May 17, 2013 | Washing Machines
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
The lock light flashes and the machine continues to try and lock even though it appears to be locked...stops filling Maytag neptune TL
Are you up for troubleshooting? I will try to keep it low tech.
Do both Lid locks remain locked (you can't open the lid ) and you just have the Locked LED is flashing?
I'm assuming if you hit the OFF key the machine will unlock is that correct?
If so I feel you have lost signaling thru the lid locks possible do to corrision. We would start on the Left Hand lid lock which would require removal and very carefully opening up the case halves of that lid lock.
Here is a pic of what we might find inside...... some corrision;
Let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Jul 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl washer lock not working my husband bought it used so I have no manuals I was able to run a load blaech water to clean it but now it just keeps flashing "od" I've left it...
If you are still having issues; The OD alarm is signaled by the control board when it has not see a lid open signal from the left lid lock for three completed wash cycles. Issue could be a lid magnet out of position or corrosion issues with the left lid lock and or plug connecting to the left lid lock. Take a look at his post. It’s for OP alarm issues associated with the left lid lock but it will give you a start point for troubleshooting. Post back if you have questions. Links for the the SM and parts for the Left Hand Lid Lock replacement info are in that post.
May 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
Top Maytag Washing Machines Experts
Sheldon Dedek
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
