Question about Krups Coffee Makers & Espresso Machines
Problem with Krups Nespresso Essenza XN 2009 Espresso Machine Nespresso krups
5 Related Answers
Anonymous
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
Anonymous
  • 3 Answers
SOURCE: instructions for Krups Gusto espresso maker
I found the manual on an Amazon.com site for the Krups Gusto espresso maker (January 2009)
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000052280.pdf
Posted on Jan 18, 2009
Anonymous
  • 5 Answers
SOURCE: nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Posted on Aug 30, 2009
Anonymous
SOURCE: how to use krups espresso machine
The metal nozzle under the rubber frother is plugged up. You can remove it with a wrench (it is threaded). I now wash mine after every use since mine plugged so badly I had to use wire to unplug it. Milk does that.
Posted on Jan 11, 2010
Anonymous
SOURCE: Nespresso Krups essenza manual XN2001- Switch broken
The machine is not switching on-I am in India-Tamilnadu-can i get it serviced any where here?
Posted on Aug 10, 2010
How do i clear the air bubble in the nespresso machine?
OK fill the tank and only use water press the small cap botton and after 5 seconds stop the machein and do the same again untill the pump gets the water into the system
Sep 17, 2014 | Krups Nespresso Essenza XN 2009 Espresso...
Need krups xp5200 manual
Krups may furnish a manual if you inquire.
Jun 18, 2014 | Nespresso Essenza C100 Espresso...
User Manual
Here you go...good luck! :) http://kitchen.manualsonline.com/manuals/mfg/nespresso/c290_d290.html
Aug 28, 2012 | Krups Coffee Makers & Espresso Machines
Where can I get spare parts for the Krups Nespresso Citiz XN. specifically the Drip tray and the base it sits on
Why don't you try "Krups" ? I would think this would be the best place to start. Ask them if they stock the spares and if not where they are available.
Feb 24, 2012 | Nespresso Coffee Makers & Espresso...
My Krups XN2005 coffee machine switches itself off as soon as I try and brew coffee from the pod. Any suggestions?
My Krups Nespresso XN2005 machine turns itself off when I try press the start button- any solutions ?
Feb 21, 2011 | Krups Nespresso Essenza XN 2009 Espresso...
There is no power in my krups xn 2000 nespresso maker . had it open and measured points from end of the cable and the control board looks good anyone know if there is something else i can do many thanks
Frequently the power button / power switch seems to be broken. Apparently a tiny film of grease builds up between the conductive material in the rubber button and the IC board.
See this video on youtube how to open it up and remove the dirt. I repaired my machine this way, takes 15 minutes, and I was surprised how only a thin film of grease could cause the malfunctioning of the button.
Feb 09, 2010 | Krups Coffee Makers & Espresso Machines
Jul 29, 2009 | Nespresso Essenza C100 Espresso...
Krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Feb 17, 2009 | Coffee Makers & Espresso Machines
Need replacement frother part for Nespresso Aeroccino
both parts can be found on amazon for about 9.99$. take a look here: Secura Automatic Electric Milk Frother and Warmer Whisk Set. I hope this was helpful. cheers
Sep 02, 2008 | Nespresso Aeroccino Automatic Milk Frother
Leaking water, does not close
I had the same problem with the nespresso krups xn20 machine. After calling the Nespresso service desk they substituted free of charge the water tank, which has a little valve with seal at the bottom. It turned out that the problem was not the seal of the water tank, but the seal of the machine (onto which the water tank is installed).
I solved the problem by using Teflon tape (same type as that used to connect for water pipes) on the water tank, applying it at the appendix which goes into the machine.
It's been working ok since then (couple of days). The only problem could be the wearing-off of the tape after some time (you will have to reapply it).
Apr 17, 2008 | Nespresso C100B Essenza Single-Serve...
Coffee Makers & Espresso Machines Logo
261 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
