SOURCE: karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Did you check if the igniters? they may be cloged up with ****. Unscrew the Sight glass on top of the boiler and run the machine (in cold or hot mode, doesn't matter, as the igniters are running all the time) and see if there are working, you should take them out anyway and give them a wipe with a rag as general maintenance item, and when you put them back in there should be about 5mm gap between them.
Less common reasons for the boiler to not work
- Faulty fuel solenoid valve, (You should hear a click sound about 5 - 10 seconds after you pull the trigger)
- Dirty fuel filter,
Take a look at those simple things and let me know if its any of these.
I have a Karcher HDS 750 1989 Year model
This machine just keeps going, it's had a fairly tough life but it has stood up to it all,
i hadent spent anything on it until about 6 months ago when i purchased a new fuel pump for it as the old was wasn't pushing 170PSI to the Disiel injector it had slowly droped 70psi, and it doesn't create a hotter burn in the boiler, but still very good for a 19yr old pump,
other than that thats all it's needed, it's still going strong to date
Very robust machine.
my e-mail is [email protected]
Cheers Matt.
SOURCE: KARCHER HDS 1000 de
hi jim i have the same unit diesel burner and diesel engine have you tryed a new accelorater cable?
SOURCE: hi,karcher hds hot pressure washer now pressure
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
SOURCE: whare can i get a
I work for one of the top Karcher dealers in the US and we can get this part for you. Visit our website at www.landanw.com for contact info or call 800.247.8103.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
SOURCE: karcher professional hds 655 steam cleaner not much water pressure
If there is nothing wrong with the machine but you have lost power over the years you have been working it. It could be that the machine needs a new pump kit or/and change the pressure nozzle.
smaller issues could be that the pump isnt turned to high pressure or if you have an servo control on the gun that it is turned to low pressure instead of high pressure.
