Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Flood switch fault - Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Sam
  • 3247 Answers
SOURCE: flood switch fault
Turn the power off.
Open the drawer as far out as possible. get a towel and hair dryer and try to dry the base of the cabinet.
Turn power on and see if fault goes away. If not then you may have to repeat but get the drawer out from the cabinet.
Causes can be several - water leakage from the inlet or drain hoses, kink in the drain hose or broken actuator link that keeps the hoses taut when you pull in/ out the drawers.
Posted on Feb 05, 2010
DW60CE dishwasher - E6 fault flood switch activated. Unit has not been use
After tipping the dishwasher on its side & it releasing its water from its tray, the fault cleared. I removed the bottom cover & inspected its internals for traces of a leak or evidence of leaking.
I could follow the calcium or detergent trail from the rear water duct connection near the top feeding sprayer arm, down the back of the dishwasher & into the tray. The lock nut on the duct where it enters through the inside S/S skin had become loose & simply needed to be tightened.
Jun 09, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I just bought a dishwasher SE34E200SK. The washing program always gets stuck in program 3 and it cant move further unless one has to turn it manually. Also it doesnot empty out the waste water after...
Hello
Most faults can be referred to the fact that the Anti Flood Overflow device has activated.
Modern day dishwashers like those manufactured that have a built in safety feature protecting the dishwasher against flooding. The technical term is 'Anti Flood Device'.
In the base of the dishwasher in the plinth there is a float switch. This is your 'Anti Flood Device'. In the event of your dishwasher over filling, the plinth fills with water, the float rises and actuates the switch.
Firstly, it will send a signal to the programmer device to notify there is a fault and output a message in the form of a code to some sort of display.
Secondly, the pressure switch acts as the water level indicator for the sump of the dishwasher so when the water level rises the pressure switch will activate the drain pump.
So before you consider throwing good money at new dishwasher, try doing a bit of fault finding your self and you might save yourself a ton of money.
Sep 10, 2011 | Dishwashers
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Error Code FL
The FL (Over Fill) error code indicates that the flood pressure switch is open (tripped). It is likely that you are getting the LD (Long Drain) fault code because the control detects that the flood pressure switch will not reset after running the drain pump. Your likely failure is in the flood pressure switch
Tapping on the flood pressure switch with the handle of a screw driver may reset it. Reassemble the washer and see if it will work properly. If not, then you will need to replace the flood pressure switch. The part number for the flood pressure switch is 8054767. You can order this part from the Sears PartsDirect website. The part number for the flood pressure switch is 8054767.
Jul 28, 2010 | Kenmore Washing Machines
F1 fault shows flood switch activated, how to
Hello there
This is how i did mine
saved about 300 dollars
First thing I did was pull the front panel off the drawer, batch%2010-23-04%200031.jpg
Fisher Paykel DD602 dishdrawer with the front panel removed.
With that front panel off, I pulled the wire harness connectors off the main control board (lower right-hand side) to inspect for gookus. None found--my quest continued.
The next step to remove the botton drawer from the unit so I could inspect the flood switch. In order to do this, I had to remove the wire harness cover on the underside of the drawer. This is what the underside of the dishdrawer looks like with the botton cover panel removed:
Fisher Paykel DD602 dishdrawer, looking at the underside of one of the drawers with the wire cover plate removed.
With the bottom cover off, I could unclip the wire harness, fill hose, and drain hose. Then I unclipped the linkage at the back of the drawer and lifted the drawer off the slider arms. All this to expose the flood switch, shown on the left-hand side of the bottom panel in the picture below:.
Fisher Paykel DD602 dishdrawer with the lower drawer removed. The flood switch in mounted on the base, left hand side.
After noting the positions of the wires on the flood switch and removing them, I unclipped the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, I could ohm out both switches and both checked good. I inspected the contacts and noticed that one of them was oxidized, evidenced by discoloration.
and clean off the contacts. That'll restore the current flow for that circuit. ." So I cleaned the contacts and reassembled the dishdrawer. I ran the top drawer and...no F1 error code! I ran it several more times just to be sure.
May 15, 2010 | Dishwashers
Flood switch fault
Turn the power off.
Jan 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
FI error message from both drawers. We had a
F1 indicates flood fault. There is no reset, machine thinks it has flooded. If machine was running OK until electrical storm, then it could have shorted the mains filter control board (DD603 models-this mains filter board also acts as flood switch), although this is unlikely to have shorted. More common is dishwasher has had a leak causing F1 fault, or corrosion on mains filter board . Open bottom drawer and shine torch underneath to see if there is any water in the base of the cabinet- if yes, machine has leaked and activated flood switch. If not, flood switch board may be faulty.
Unfortunately, access to this flood switch control is permitted only by removal of the bottom drawer- recommend calling technician unless very keen!! If keen, read on!!
-To remove drawer- there is a tag at the bottom front on each side of drawer when you open it -just below the round plastic plug. You need to push this tag in and slide backwards on each side, then drawer will lift out-Careful as hoses and wiring still attached, but long enough to allow access. Mains filter control board is located under plastic cover at left rear- press tag on plastic cover and slide to the right- you will now see small electronic board. This is the mains filter board that doubles as the flood switch. It is held in place by 1 screw- you need to remove wires from board before removing it). Check circuit board for corrosion or evidence of short circuit- if so, replace circuit board.
Good luck, but advise seeking professional help unless you very confident!!
Aug 10, 2009 | Fisher and Paykel Dishwashers
BEKO DWD4310W Will not empty
yes it will be the main pcb that is at fault they normally lose a neutral to the pump when they go down
Jun 27, 2009 | Beko 24 in. D3731F Free-standing...
Pump continuing to run -Asko D3100
Micro switch was actually faulty,moisture had entered the switch and caused internal tracking and shorting out the micro switch ,making the pump run continually as it thought it was still in flood mode.
Flood appears to have been caused by a pin hole in the water fill hose in the base of the dishwasher,causing water to spray on the micro switch and eventually biuld up in the base of the machine.
Aug 05, 2008 | Dishwashers
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
71 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Mark Davis
Level 1 Expert
Bruce Denton
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
