Canon F-502 Calculator Logo
A
Anonymous Posted on May 03, 2014
I want to increase the decimal places on the Canon calculator
1 Related Answer
Anonymous
  • 50 Answers
  • Posted on Jun 28, 2011
SOURCE: I have the Canon LS-100TS
Try switching between business and tax mode, the little toggle switch at the top of the calculator.
If that doesn't work repost.
Hope that helps
How do i increase the number of decimal places on hp c12
Press f then a digit for the number of decimal places you want after the decimal point.
Decimal places
Press f then a digit representing the number of decimal places you want after the decimal point.
How to increase the decimal places in the answer
Press 2ndF TAB then a digit representing the number of digits after the decimal point. See "Adjusting the Displayed Decimal Places" beginning on page 7 of this manual: http://www.fixya.com/support/p193841-sharp_el_733a_calculator/manual-5340.
That's the page numbered "7" in the manual, not the seventh page of the PDF file.
1helpful
Decimal placing
Above the feed button is an area for controlling the decimal placement. By leaving the slider on +, you have to manually put the decimal in.
0 - Means no decimal will be placed.
1 - Put it one place to the end. Ex: 4132.5
2 - Will make it read 413.25
3 - Will be 41.325
And so on.
4helpful
How to add decimal on SHARP EL735S
how do i increase decimal places on a sharp el735?
10helpful
Canon f-502 user guide number of desmial places need to change
I have not been able to find a link to an online manual (Canon does not have it)
What I am going to suggest comes from my personal experience with calculators.
To change the number of decimal places, try
[2nd][FIX] n where n is the number of decimal places you want.
Hope it helps.
39helpful
I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183 Introduction This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation. Instructions for standard format
  1. Press and release the gold PREFIX key (f).
  2. Press the number key for the desired number of decimal places (0 through 9).
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
1helpful
Decimal places
How many decimal places are in the answer of this problem? 3.7844236 times 456.93874513
EL-1197PIII Sharp Calculator
move switch for decimal places to "add",or to number "2" for 2 fixed decimal places
old marine
old marine
ZJ Limited
ZJ Limited
