My selphy printer 730 only prints the top half
SOURCE: SELPHY printing too dark
I have some experience with color profiles, after trying to fix this problem by changing the profiles in Photoshop, letting the printer manage color, leting PS to do so, and every possible thing.... I found that increasing brightness, and 2 points of saturation on the printer dialog pretty much prints what you see on the iPhoto screen. I have the Selphy 740 not the ES1, but might be the same....
SOURCE: Canon selphy cp760 photo printer will not print on my computer
Normal
0
Could have a corrupt driver.
Disconnect
the printer or at least be sure it is turned off. I'd do
both and when the CD software program asks you to connect the printer
to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: Selphy ES1 printer switches on,
remove all the connection go to control pannel printer and default ur Selphy Es1 printer
SOURCE: Selphy 510 won't print from computer, print ok from camera ...
Did you download and install the proper Vista driver from Canon's website? If not, I would suggest that. If you have, then try opening the device manager and look for the printer. Reinstall the driver and just direct it to look in the proper folder for it.
SOURCE: I insert ink cassete into it"s selphy cp780 photo
Go to section on Error Messages at page 32 of the User Guide found at:
http://gdlp01.c-wss.com/gds/0/0300002060/02/SELPHYCP780_PUG_EN_03.pdf
It will tell you to remove and reinstall the ink cassette. Try this and make sure you install correctly as per instructions on page 11 of the User Guide.
If this does not resolve the problem, do a complete power down of the printer. Turn off and unplug from the power supply. Lets rest fro a few minutes and then plug back in to the power supply and if necessary turn on power. This should allow your printer to reset and hopefully recognize that a new ink cassette has been installed.
Trust this helps. Please vote. :)
