The chain in my tto toilet came off of the pink flapper. how do i repair this and will it hold
The flapper assembly alone can be replaced. Turn off the water supply to the toilet and manually lift and remove the flapper from the fill tube - if you have to cut it, that's ok. Inspect the lip the flapper sits on, looking for chips or flaws that make that surface uneven.Go to your local hardware store - they have a large variety of replacement flappers from just a couple of dollars to pricier versions. Matching flapper color is not important - design and style is! Your fill tube probably has ears on the sides - you'll want to make sure you get an eared replacement. Usually the replacement flapper will have "extra " parts cast into the rubber for multiple applications, and these can be removed with scissors or a razor knife. Follow instructions provided with the flapper and know you just saved a healthy amount of cash over a service call!
