Macally BTMicro Mouse Logo
Question about Macally BTMicro Mouse
How to put a KP-C1311B Optical Wireless Bluetooth Mouse into pairing mode
1 Related Answer
Radu Nemtanu
  • 44 Answers
SOURCE: how do I pair a Bluetooth C1311B Mouse, there is no connect button on the bottom of the mouse just a power on/off switch ?
You have to press both left and right button and the middle.
Posted on Sep 12, 2012
1helpful
Pair to iPad
Till now I did not know you could pair a mouse to an iPad. When someone is selling mice you can connect via bluetooth, they will give you the manual to. I hope you know, the iPad is not a computer on which you can connect lots of things. Only when Apple allows you to put anything on, or connect via bluetooth, it can work. Not when you think it should be great.
Because Apple made it possible to connect their key board to the iPad, you now can buy third party keyboards that work with the iPad.
Changing the batteries does not make the mouse work. the cursor is visible on the screen but will not move. what next?
Have you tried re-pairing your mouse? Should be a button on the bottom of the mouse and a button on the wireless antenna device. Or, If your using a bluetooth mouse make sure bluetooth is turned on, on your computer.
3helpful
My laser logitech bluetooth mouse won't connect to the laptop again
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Mouse
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth Mouse will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
3helpful
2answers
My mini wireless optical mouse will not pair
I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is theprocess of coordinating your mouse's transmitter with your mouse's receiver. Itrequires both parts to operate on the same frequencies, usually by using thesame identification code. Pairing takes place to try to eliminate interference.Some devices automatically pair both devices at start up; others need to bemanually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteriesin mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) andplace the batteries. Cover, Now you can see thered light glowing on the bottom of the mouse, now your mouse is ready topairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE willbe ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, ifmouse curser is not moving then press BUTTON 2 one time – now defiantly yourmouse will work, If you need any other technical support for GMAX, products please contact satish kumar (countryhead gmax technologies)
I can't operate the mouse. its not working.
Install fresh batteries, turn it on and make sure your bluetooth dongle is installed and active. If you have never paired this mouse with it's receiver, then you will have to put them both into pairing mode, and once paired you should have no problems.
2helpful
2answers
Dell wireless keyboard and mouse will not work
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Pairing WOM20 with Computer
i think you may be getting wireless confused with bluetooth. Your mouse is wireless and it needs the wireless sender unit connected to a usb port, but this is not bluetooth, it picks up the wireless signal from the sender to work. You will also need to install any software that you got with the mouse (if any), as you will need to set up the button and click functions, unless it just uses the normal pointing device driver in windows.
Open Questions:
Top Macally Computers & Internet Experts
Paul Bade
Mike
ADMIN Andrew
ADMIN Andrew
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
