Question about Oster 12-Bottle Wine Cellar - Black
Front door parts
Front door frame is broken
Hi I have a Hoover 5005D drier which was going
I USED A PIECE OF CARDBOARD WRAPPED IN DUCK TAPE TO WEDGE BETWEEN THE DOOR AND THE FRAME. IT WORKED FINE FOR THREE YEARS
Aug 05, 2013 | Hoover ACCESS DOOR-U7069/71 - 35121001
Model wm0642hw front load. it leaks by door frame.rubber seal with clamp.only 2 years old. do i need to change the door frame outer part a151? thanks for your response in advance
Hi, If the door isnt loose or broken? Its more likely to be the rubber door seal if its leaking between the seal and the door glass. Check the edge of the seal where it touches against the glass for damage or ware if its ok clean any soap residue or bits from the glass.If it still leaks change the door seal.
Regards Elect App
Jul 13, 2011 | LG WM-2277HW Front Load Washer
I have ordered a replacement battery door for a Nikon Coolpix L20 and want to know how to change it.
It's doable. A few things to consider before you start.
1. Make sure it's the door and not the frame of the camera itself. I got a new door and replaced it only to find that the part of the frame that receives the door latch was broken.
2. There are several fragile parts in the camera (notably an aluminum strip on the bottom of the camera, opposite the battery door). I would suggest that if you are nervous about operating on cameras and the like, you find a friend who is comfortable with this.
For removal of the back half of the frame, see http://www.youtube.com/watch?v=Xg6vczoliB0
You will need, however to pry off the FRONT part of the frame to get to the pin that holds the battery door. Do this carefully; you don't need to get it off completely to see the head of the pin.
The head of the pin is bent at a 90° angle. The head is about 2 millimeters long. You will need to get a fine instrument (a sewing needle will do the trick) to get beneath it, and pull it out. You only need to pull it out about 3/4 of the way to lift the battery door and slide it off.
Now, just do the above in reverse to reassemble the camera. Snapping the back and front into place can be tricky, so look carefully how the screw holes need to meet parts of the frame before pressing too hard.
Nov 08, 2010 | Nikon COOLPIX L20 Digital Camera
Flase door open reading on my aficio 350. The door is shut. The machine is showing that the door is open but it not. It close as it should be.
when the door closed it actually activates the switch. see on the door if any plastic piece from the frame is broken or not and locate where in the machine does the front cover activates switch. it will be easy to find the broken part.
Sep 23, 2010 | Ricoh Aficio MP 161 Black and White Copier
The door handle has broken off and a piece of the door where the screws for the handle go is broken. Right now, the only way to use the washer is by taping the door shut. Is it possible to replace the...
from your description It seems to me you need frame #8182628 and handle #8181846.
the door comes as separate parts, not an assembly, but they are pretty straightforward to put together
Apr 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Broken plastic front door cover.
I take it you live in Perth, Scotland and not Perth Australia.
Contact whirpool direct and say that you need part number 4812 440 10817 it shows on whirlpool database as a glass door frame but it means it's the plastic around the glass ( I promise you) acording to my system ( I'm a Whirlpool engineer) you can get one direct from us for about £22.77 plus delivery or you could go to your local retailer with the part number given and see if you can get it cheaper
Feb 23, 2010 | Whirlpool AWM6100 Front Load Washer
Need replacement part for front dryer door sensor - broken
i sell parts online you can visit whirlpoolpartssurplus.com and get the phone number off there and i can order it for you
Jun 26, 2009 | Hotpoint NVL333GY Gas Dryer
Door latch replacement
remove spring from around front of door seal roll seal away from door frame remove the 2 screws holding lock assembly to frame pull latch toward opening unplug the wires reinstall in reverse..reinstalling spring on door seal will be hardest part but not too bad
Nov 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Closing the dryer door
you need a part number 5366021400 latch kit I think take your model and serial number to you local appliance dealer and they will probably have one on the shelf and its so easy to install just pull the old broken part out and replace with new one
Nov 15, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Oster 12-Bottle Wine Cellar - Black Logo
52 people viewed this question
Top Oster Furniture Experts
Tom Chichester
ray gallant
Are you an Oster Furniture Expert? Answer questions, earn points and help others
