SOURCE: ON MY PRONTO M91, BATTERIES ARE 0NE YEAR OLD, BUT
mcdevito75 here, The battery / ies could be old even, at 1 year old. Contact Invacare online or by phone.
SOURCE: The Pronto will not keep
Mckinzie the lights will flash when charging because of the inhibit mode. After you unplug the charger and turn the chair on do you get any lights at all on the battery indicators? If not lift up the seat and check your battery cable connections the neg cable from the rear battery should be connectd to the positve side of the front battery and the rear neg should plug into the small connector of the other cable. Make sure then that the large double plug is connected to the double plug going to the controller. while the seat is up then turn the chair on to see if all the lights come on. If not check that all your connections at the battery posts are tight. Also check under the two red positve battery post covers the two fuse links to make sure they are not blown. If all of this checks out the chair should come on and operate correctly Hope this helps
SOURCE: My Pronto 51 won't drive
Hi I really don't know the cost of the brake because it depends where you get it. You can contact Invacare tech support @ 1-800-333-6900 and ask about the brake and the cost With some chairs the brake is part of the motor and can't be sold seperately. Did Medicare buy your chair? If so they will pay for the repair. If they did contact Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 and ask to get your chair repaired. Even if Medicare Didn't pay for your chair both of these Services can quote you a cost of repair Hope this helps
SOURCE: pronto M6 chair will not work. When the power
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
SOURCE: one red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
