Question about GE GSH22JFR Side by Side Refrigerator
DISPENCE NOT WORKING
EVERY THING STOPPED WORKING. NO LIGHT,NO CUBES, NO CRUSHED ICE, AND NO WATER. BT THE ICE MAKER WORKS JUST FINE. CAN YOU HELP ME? THANK YOU MARY
5 Related Answers
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Posted on Aug 26, 2007
WILL3464
SOURCE: ice maker does not dispense cubes
THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
Posted on Jan 23, 2008
Anonymous
  • 65 Answers
SOURCE: Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Posted on Jan 27, 2009
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: ice maker only crushes/does not cube
Remove the ice bin. Look at the back wall, behind where the bin was. You should see a rectangular hole, about 1.5 x 1 inches near the bottom of where the ice bin was. There should be a white plastic part inside the hole. This plastic part should be able to be lifted up with your finger, and drop down again when you release it. If is does not move, it may be frozen, or the electrical solenoid connected to it may have melted. If the part moves freely, just replace the ice bucket and try to dispense cubes again. (the metal arm sticking out the back of the ice bucket might have gotten on the wrong side of the white plastic part in back)
Posted on May 23, 2009
Anonymous
  • 296 Answers
SOURCE: Ice maker only makes crushed ice, no cubes
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
Posted on May 27, 2009
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
My ice maker produces ice just fine, however when I try to receive "Cubed Ice" it dispences it "Crushed". It makes no difference if the front panel "Cubed Ice" button is pushed or the "Crushed Ice" button...
Not sure what brand you have but I had a similar problem with a dispenser once. The ice dispenser would freeze up and couldn't change over from one to the other and I'd have to take it out and let it thaw occasionally and then it would be fine for several months again. If your ice bin is in the door this may be what you need to do.
Jan 25, 2018 | KitchenAid KSRG22FK Side by Side...
Ice maker will not make ice cubes, only crushed ice.
take out your ice bin the look in the back of the freezer and ytou will see a small hole with a plastic sqaure actuator.hold the door switch closed and make sure the unit is selected for cubed ice then try and dispence ice if the swaure plastic acuator moves up it is working fine it shoeld drop down when you release the dispencer arm.if it dropps back down then make sure that the metal bail arm is properly inserted into the hole in the auger case when that actuator moves up this opens the small plastic door on the ice bin to allow subed ice to come out.make sure there is no ice build up on the ice bin that would stop the trap door from opening.good luck with you fridge i hope this helps you out,let me know how thing s go for you.
Jan 20, 2010 | Frigidaire FRS23H7C Side by Side...
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Will not dispence ice, crushed or solid cubes, will dispence h2o
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
and if the ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 09, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
Ice cube button is lite but the only dipenses crushed ice
We have had this problem on occasion. The lever up in the ice dispencer gets jammed with frost and ice. If you remove the ice bucket/auger and let it thaw or just rinse it with water and dry it. Give it a try. -Matt
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
GE GSH22JFR Side by Side Refrigerator Logo
60 people viewed this question
Top Refrigerators Experts
gbob59
Marvin
Marvin
