Question about HP LaserJet 2430 Printer
Tray 3 jam error, but no jam - HP LaserJet 2430 Printer
1 Related Answer
Anonymous
  • 34 Answers
SOURCE: printer will jam on mulitiple page print jobs gets
OK you said you replaced the rollers. If you have not repalced the SEPERATION PAD, (located directly under your pick up roller....thats your problem. Easily done.
Posted on Mar 12, 2009
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Error oki b6100 e2
This error often comes when there an paper jam or paper tray 1 or paper tray 2 or 3 is empty,make sure that you have enough paper in the trays and secondly make sure that you have there is no paper jam in paper roller, even an tiny particle of paper can cause this error.
Please open all the access of your printer pull out all the paper trays and clean it properly with air blower, this can fix this error.
Sep 02, 2011 | OKI C5400 Laser Printer
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
LJ3700 page tops half- way through fuser. Bob
13.01.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. 13.02.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. these are areas that you mentioned and fixes to them http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478#A3 this is the link to all error codes for your printer you might want to print these out and keep safe
May 07, 2008 | HP Color LaserJet 3500 Printer
HP LaserJet 2430 Printer Logo
23 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
