SOURCE: Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and
defaulted to 1500. The router model that you have doesn't have MTU
settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
SOURCE: Mtu setting
maybe the manual of that router helps a bit:
http://www.zhone.com/support/manuals/docs/62/6218-A2-ZB23-10.pdf
SOURCE: i need help changing my mtu setting for my
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on WAN settings and change MTU settings then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
