Question about HP Deskjet 3510 e-All-in-One Printer
My printer wont print black ink 3510e all-in-one but it prints color?
5 Related Answers
Anonymous
SOURCE: my printer wont print in color & its a new color ink cartridge
have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
daveywhite
Posted on Nov 11, 2008
Anonymous
  • 81 Answers
SOURCE: colors do not match up
Have you tried a few alignments? Also you can try turning the printer on and when you start hearing the alignment turn the printer off ... do this a few times and see if this helps.
Also you can try to manually align the cartridges.. to do this turn the printer off. Open the front cover to reveal the cartridges. On the right hand side you can see some gears. Try to turn one of these slightly.. one click (1mm) should do it. Now turn the printer on and let it align itself
Posted on Dec 16, 2008
Joe Fine
  • 628 Answers
SOURCE: Printing with only the Black ink cartrige.
Yes. The printer won't operate without both cartridges installed, even if one is empty.
Posted on Mar 15, 2009
PrintDocta
  • 217 Answers
SOURCE: Cannot print in black because color cartidge is out of ink
There is a 'low toner' override in the menu system, but if this has NOT been set already, a 'flag' will be set on the chip on the cartridges that are low/empty.
The printer needs to 'see' cartridges that are usable, i.e. NOT empty, in order to function.
It is possible to replace just the chips on the colour cartridges, but then any colour printing quality could be compromised of course, as the colours will be low/empty. You would then be able to use the printer as if it were a mono laser, just changing the black cartridge when needed
Posted on Apr 29, 2010
Michel Smith
  • 1218 Answers
SOURCE: My printer is not printing
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Posted on Sep 09, 2010
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Black ink wont print, but color works fine
The black cartridge needs replacing it sounds like. On many printers, that is the only way that you get black.
Jul 05, 2009 | Dell Photo 964 All-In-One InkJet Printer
Refilled my black ink but my color ink is empty so it wont print
Apparently I just had the same problem and I managed to fix it! Click on the OK button on the printer to ignore the low ink level error, then you'll be able to print and scan.
Jun 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Wont print black because it doesnt have color ink
So for now, you can change the print settings to only print in black.
Change the print properties/ colour to grayscale.
May 11, 2009 | HP PSC 1610 All-In-One InkJet Printer
Color ink cartridges empty, printer wont continue to print
select print black only from the print or page set-up.
Mar 30, 2009 | HP Color LaserJet 2600n Printer
Ink cartridge light keeps blinking BEWARE SPAM NUMBER 1-800-532-4187
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
HP Deskjet 3510 e-All-in-One Printer Logo
efs_perpends
efs_perpends
k24674
